Installing a switch for the fan
Old Apr 9, 2007 | 06:49 AM
platinumx6's Avatar
Default Installing a switch for the fan
I just bought me a b16 rex and to turn the fan on you have to go into the bay and plug it in. How would i go about installing a switch and run it into the cab. Thanks.
Old Apr 9, 2007 | 08:11 AM
arc_55's Avatar
i would hook up the fan properly as having engine temperature consistent is important. i would not put a manual switch in.
Old Apr 9, 2007 | 09:38 AM
YoungKadafi's Avatar
true i was gonna do this, but found out how bad it was.
Old Apr 9, 2007 | 10:30 AM
platinumx6's Avatar
Default Re: (arc_55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arc_55 &raquo;</TD></TR><TR><TD CLASS="quote">i would hook up the fan properly as having engine temperature consistent is important. i would not put a manual switch in.</TD></TR></TABLE>
i keep reading this but i have replaced all the fuses it says to switch! I cant find much info specifically for a b16 crx if that matters??
Old Apr 9, 2007 | 11:05 AM
Perfectionist's Avatar
Default Re: Installing a switch for the fan (platinumx6)
Fuses aren't the problem if the fan runs when you plug it in. Control is the problem. The harness has probably been hacked and the fan circuit is grounded all the time, that's why it runs right away when plugged in. It should be controled by a thermo-sensor on the back of the block that does the grounding when a certain temperature is reached.
Old Apr 9, 2007 | 02:59 PM
arc_55's Avatar
Perfectionist has said it right, take the time and find out your issue. The short to ground is one possible failure, but if you can get a wiring diagram and go from there.
turbosivtec
Oct 21, 2008 06:19 PM
GSE980
May 15, 2007 09:00 PM
Nameless Warrior
16
Dec 13, 2006 07:19 AM
fridexter
13
Dec 26, 2004 05:01 PM
wardstar
Aug 30, 2004 01:45 PM
