raene, or anyone else, please answer (or try to)
I think I know. But I really don't
ok after i saw your list of engine codes i realised this whole time ive been misled
heres the deal,
i have a 91 si hatch w/a b16a and s1 tranny, I/H/E, and field vtec controller
the prob is the damn check engine light and code 7 (that i thought was TPS)
is TPS the same as throttle angle sensor??
i got a TPS from the junkyard and put it on, mine was broken (physically)
i can only get voltage up to 3.6VDC at WOT with dremmeled out holes
it runs fine and strong, just rich as bill gates.
any advise is appreciated
thanks
heres the deal,
thanks
I don't really know much about the TPS, sorry
Code 7 is the TPS, yes. I've never had a problem with mine.
If the car seems to be running good, then it's probably not a TPS problem. If the TPS is going I'd think that you'd feel a lot of surging/leaning out because it wouldn't read a steady voltage. Do you have a manual to check the acceptable voltage range?
Code 7 is the TPS, yes. I've never had a problem with mine.If the car seems to be running good, then it's probably not a TPS problem. If the TPS is going I'd think that you'd feel a lot of surging/leaning out because it wouldn't read a steady voltage. Do you have a manual to check the acceptable voltage range?
ive heard (a lot) that .5vdc @ idle and 5vdc @ WOT.
like i said 3.6 is all i can get
i just really want the CEL to go away
crnimacak
Jan 19, 2006 04:59 PM
