Help. Lights keep dimming. Short somewhere?
Old Apr 8, 2007 | 08:18 PM
DammitDan's Avatar
Default Help. Lights keep dimming. Short somewhere?
I just bought a 98 EK. I didn't notice one issue with it since I bought it during the day and wasn't that noticable, but now is driving me nuts. The lights keep dimming and brightening by themselves. It's a fast dimming and brightening. Don't matter what light it is either, every single light and anything that lights up.
Can it be the alternator? Should I get the charging sytem checked. Also, it doesn't matter if the running/head lights are on or off. It only happens when the car is running. Also, the speed sensor doesn't work. The speedometer needle starts jumping around by itself, even while not moving. Can this be the same issue or just a bad speed sensor?
Old Apr 9, 2007 | 04:31 AM
DammitDan's Avatar
Default Re: Help. Lights keep dimming. Short somewhere? (DammitDan)
Any suggestions or anyone ever have a similar problem?
Old Apr 9, 2007 | 11:19 AM
Perfectionist's Avatar
My guess is a partial failure of the alternator. Have it tested. In the mean time, make sure your ground cable is tight at the battery, and check the other end where it is bolted to the trans. Corrosion and vibration could have worn the cable down to just a few strands.
Old Apr 9, 2007 | 03:55 PM
NathanielH's Avatar
Default Re: Help. Lights keep dimming. Short somewhere? (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">My guess is a partial failure of the alternator. Have it tested. In the mean time, make sure your ground cable is tight at the battery, and check the other end where it is bolted to the trans. Corrosion and vibration could have worn the cable down to just a few strands.</TD></TR></TABLE>
great advise, i agree 100 %
Old Apr 10, 2007 | 09:58 AM
PHDZINE's Avatar
Default Re: Help. Lights keep dimming. Short somewhere? (NathanielH)
IF the alternator checks out ok...it sounds like a bad ground issue. Check all your ground wires....make sure you check all of them, not just the ones in the engine bay.
DammitDan
Apr 9, 2007 09:22 AM
BigIslandBoi
Aug 21, 2006 06:33 PM
{StatuS ChecK}
Mar 29, 2005 10:16 PM
Turbo'dMex-A-Keen
Apr 10, 2003 05:22 PM
