car over heating
Old Apr 8, 2007 | 05:59 PM
VvPeachyvV's Avatar
Default car over heating
i know this isn't a toyota forum, but i have a 92 civic hatch and i always come here for problems regarding my engine and u guys always provide me with a slew of info to get the job done on it. my girls car (95 toyota tercel) is overheating very quickly, the temp gauge goes up all the way to H after about 2 minutes of driving, but it goes down when ur driving at speed, but when it stops it goes right back up, my thoughts were the thermostat, but it was just replaced last year (or was a quick fix trick, can't remember what was done) but i figured it was either that or a head gasket, but it doesn't run like the head gasket has been blown or anything like that, and theres no leaking around it. so i'm at loss as to what it could be besides a malfunctioning hose or a sensor. please help asap. thanks guys.
Old Apr 8, 2007 | 06:36 PM
Diet coke boii's Avatar
Maybe fan clutch?
Old Apr 8, 2007 | 06:43 PM
hatchaddict's Avatar
Default Re: car over heating (VvPeachyvV)
Have you checked your fuses to make sure they're good.I had the same problem but I changed my thermostat again.And I had just changed my thermostat about two months ago.Maybe a defective one.gl
Old Apr 8, 2007 | 10:52 PM
VvPeachyvV's Avatar
Default Re: car over heating (hatchaddict)
thats what i thought
Old Apr 9, 2007 | 01:23 AM
iaredavid's Avatar
Test out the thermostat by putting it in a bowl of near boiling water to see if it opens up. Once I bought a new [aftermarket] one that didn't open, so I exchanged it and problem solved.
One trick my dad did to his overheating '76 corolla, which you should try at your own risk... Was to drill small holes in the side of the thermostat. I guess it flowed enough water to keep the engine cooler.
Does the radiator fan constantly turn on? Does it turn on at all?
Does the coolant look right?
Is the radiator corroded to death?
Is there a kink in the radiator hose? One time, I saw a head gasket go and oil leaked into the coolant. It made the radiator hoses expand, and one expanded to the point it collapsed on itself. Instant overheat.
Old Apr 9, 2007 | 05:03 AM
94delslo's Avatar
Default Re: car over heating (iaredavid)
i had this same problem as well. if its not the thermostat, check your water level and make sure there is no air pockets in your system if you havent already. im not sure about toyotas, but hondas have a bleeder screw to remove the air.
Old Apr 9, 2007 | 06:48 PM
VvPeachyvV's Avatar
Default Re: car over heating (94delslo)
will do. thanks all for being cool about this, help is appreciated.
Old Apr 9, 2007 | 09:02 PM
jdmfrog's Avatar
check the radiator cap... replaced it if tis busted.
Old Apr 15, 2007 | 10:59 AM
VvPeachyvV's Avatar
Default Re: (jdmfrog)
nah the radiator cap is fine, i replaced the thermostat today and its still doing the same thing, only now its starting to stay hot, and the heater is blowing cold air instead of hot air, any ideas?
Old Apr 15, 2007 | 11:00 AM
VvPeachyvV's Avatar
radiator fan turns on and off fine, i checked for kinks and couldn't see any
Old Apr 15, 2007 | 12:58 PM
VvPeachyvV's Avatar
waterpump maybe?
Old Apr 15, 2007 | 05:54 PM
VvPeachyvV's Avatar
any ideas at all?
mvtello1234
Jun 26, 2017 06:50 AM
pro306
18
Jul 4, 2013 05:35 AM
91legend
38
Nov 29, 2012 12:22 PM
FATBOYeg6
17
Mar 1, 2005 05:51 AM
lostsol
Aug 19, 2002 08:38 PM
