please help
Old Apr 8, 2007 | 04:04 PM
thermalteg's Avatar
Default please help
i got a 92 civic with a b16 a sir2 in it and i get a little smoke and some exhaust sut on the back someone said o2 sensor please help me
Old Apr 8, 2007 | 04:07 PM
hondachris1994's Avatar
prolly runnin rich, unless ur rings are starting to go
Old Apr 9, 2007 | 02:19 AM
thermalteg's Avatar
Default Re: (hondachris1994)
i rean a compression test and i got 155 on all 4
Old Apr 9, 2007 | 05:19 AM
97Ej6mike's Avatar
Could be from a number of problems.
If theres soot from the exhaust on your back bumper, it means your running rich, so to solve that, there are a number of things you can do.
- Put some LucasOil additive in with your next oil change to help slow any ring leakage. Helps fairly well.
- Replace your spark plugs, one or more may be fouled or even dead. Also, have your distributor checked for any bad wiring, and your fusebox next to the battery as well.
- If your running an old, or even no CAT, that would be a reason why.
- Make sure your map senor is running right, if it werent, then your ECU is putting more fuel in than you need, which would cause you to run too rich.
- Make sure your running the correct ECU.
Old Apr 9, 2007 | 06:02 PM
thermalteg's Avatar
Default Re: please help (thermalteg)
well its not bad its just a puff when i get on it a little the ecu i beleive is a skunk 2 so i dont know and i could get the lucas **** but will it hurt anything
CD7Modder
Mar 26, 2012 04:28 PM
Tinoo
Nov 3, 2010 04:21 AM
RaPtUre0182
Apr 3, 2008 08:21 AM
ActiveAero
Sep 9, 2002 04:39 AM
Type R1
Apr 17, 2002 07:39 PM
