sleeve it
gota question, noob here trying to learn so if u got smart remarks take um somewer else. what does it mean 2 sleeve a block? and why would u? also an irrelavant question....wen dus the vtec for the b18c5 kick in?
thnks in advance
thnks in advance
sleeving a block is done to get rid of the somewhat brittle stock piston sleeves and replace them with, usually iron, sleeves so you can run massive amounts of boost and create a ton of power.
i think its 5500rpm.
this is sleeving: https://honda-tech.com/zerothread?id=565375
useful when you want to make lots of power and/or run bigger than stock bores
spoonhatchblack
Dec 5, 2005 10:36 PM
spoon23_JDizM AkA SpOoN20
Dec 7, 2004 03:43 AM
Louie_EM1
Sep 28, 2004 12:37 PM
