slave cylinder problems
about a week ago Ive been having problems with the clutch, i opened the reservoir and found no fuid at all, so i put some more (about a few ounces) and clutch pedal felt better. i changed the master about a month ago, do i need to replace the slave cylinder?
You need to find the leak. Just because the master cylinder is new does not mean it cannot be leaking. Top off the reservoir, wipe everything down near the master and slave cylinders, and press the clutch about 100 times. Search for leaked fluid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">You need to find the leak. Just because the master cylinder is new does not mean it cannot be leaking. Top off the reservoir, wipe everything down near the master and slave cylinders, and press the clutch about 100 times. Search for leaked fluid.</TD></TR></TABLE>
good idea thanks
good idea thanks
RiCE On IcE 2
Mar 6, 2003 03:47 PM
-BlueGSR-
Dec 21, 2002 07:30 AM
