Starts then dies in cold weather when the motors cold
well we had a rush of cold weather all a sudden and now when i leave work at night when the temp has dropped when i start it itll die if i dont give it and hold gas. while i hold it at a certain rpm it sounds as if its missing every few secs, but once i get a bar on temp gauge its fine. ne 1 have ne ideas?
during the winter when it was doing this often i cleaned iacv egr and fitv, but didnt help problem went away in the warm weather. ive also replaced ect sensor.
I have a similar problem with my '01 SH. If it gets cold, like below 40 degrees or so, it has a real hard time starting. It does sound like it's missing, but once I've tried starting it a few million times and the temp goes up a bit, it starts. I don't know what causes this either (some help huh?) but I've heard rumors that it's just an annoying V-tech side affect? (effect? damn, out of college, can't remember my grammar to save my life?) Luckily I live in Cali so it doesn't get too cold here for too long. If you purchase a heating blanket and put in under the hood for about half hour before you have to leave, it helps. Good luck. -Chris-
i dunno lol im pretty sure theres a way to fix it other then a blanket lol good idea but the main cold weather is gone we just had a cold front move through. any one else?
My car has a similar problem, though I can somewhat attribute it to the stage3 cams bumping my valves around.
I have another problem I think is related, randomly it starts and wants to die unless I hold the gas for like 30 seconds.
My next step is getting a fuel pressure guage, I suspect a failing fuel pump.
I'll let you know if I figure anything out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">Normally I would suggest the same, but I have an STR throttle body, aka no fast idle valve, so thats not my prob....</TD></TR></TABLE>
true, but I was talking about Chris' motor. His is stock, so I know he has one. Wouldn't hurt to check it out.
I gotta figure out why my motor was running lean. B/c I believe that is why my piston was so damn scarred. I know the piston rings were just worn, and that was what was causing my oil consumption...but I dunno.
I'm diving into mine tonight.. my 4th gen does th same thing.. if I don't give it gas, and let it stall, the next time it turn it over it starts RIGHt up..real quick... god I wish I could work out all these bugs with my car.. royal PITA. i can drive, but it acts up all the time..
bossm
Jan 22, 2009 04:31 PM
