How do you wire up the resistor pack to an ek harness
im trying to wire up this resistor pack(obd1) to an obd2 ek harness. i know where the red wire on the resistor pack goes and that the other black wires go to the yellow/black stripe wires from the harness. but which injector goes to which one. they are all the same color and im needing to know the order to wire them up in
Under the intake manifold on of EK or OBD2B cars... there is a plug that is a dead end plug and has a cap on it... All the wires going to it are yellow with a black strip.
If you dont find the plug under your intake manfold.. its need your brake booster.. under the hood latch area.
Test each wire to find out witch one is going to what # injector.. (1-4) .. The yellow and striped are placed in randon order.. You will find one wire on the dead end plug that has 12 volts.. run the red wire to there... and your done.
simplsi
Jun 8, 2007 08:01 AM
6SPD_EK
May 26, 2006 09:01 AM
