how long do oil pumps last?
Old Apr 6, 2007 | 11:12 PM
nexxxt's Avatar
Default how long do oil pumps last?
oem type r/gsr/etc.... revving to 9k(if that matters)...500whp etc....
im going on 4years....how long have you guys had your pumps in before changing them?
Old Apr 7, 2007 | 05:57 AM
alpha's Avatar
Default Re: how long do oil pumps last? (nexxxt)
Four years is too long IMO. Not to mention I am sure in those four years you have put quite a few "street" miles on it I have about 10,000 miles on mine and will be replacing it here shortly
Old Apr 7, 2007 | 06:01 AM
nonvtecallmotor's Avatar
Default Re: how long do oil pumps last? (alpha)
Oil pumps last a long time at 9k rpm and under. You start to have a problem when you go over 9k rpm, but if you have 4 years on it it sounds like time to change it LOL.
Old Apr 7, 2007 | 07:11 AM
nexxxt's Avatar
Default Re: how long do oil pumps last? (nonvtecallmotor)
hmmm, what wears out on them, the gears?
Old Apr 7, 2007 | 07:31 AM
alpha's Avatar
Yes. The gear wear over time. If you have an oil pressure gauge what does your oil pressure look like at idle, 3000RPM and 6000RPM?
Old Apr 7, 2007 | 07:31 PM
nexxxt's Avatar
looks like i need to check my oil pressure to see where it is at... where should the oil pressure be at idle, 3k, 6k etc.... thanx
Old Apr 7, 2007 | 07:48 PM
esedulerp5tenin's Avatar
i tried asking in the prelude section, but no one replied.
if i take off my oil filter and crank the motor and no oil comes out, is this 100% without a doubt a blown oil pump??
Old Apr 7, 2007 | 08:38 PM
alpha's Avatar
With that mileage I would say 12psi - 20psi idle, 50psi - 60psi 3000RPM and 60psi - 70psi 6000RPM
Old Apr 7, 2007 | 09:32 PM
nexxxt's Avatar
thanx, im going to check it out ....
if you think you oil pump is blown, stop cranking your motor....
Old Apr 7, 2007 | 09:53 PM
gisserhatch's Avatar
^^^ werd...lol
Excusetobooost
Jun 9, 2020 01:19 PM
drlagares
Aug 8, 2016 06:43 AM
LostCRX
Jun 21, 2005 07:12 PM
Monkey Fing a Coconut
Oct 31, 2004 05:29 AM
Harassing Herbs
Mar 16, 2004 05:09 PM
