NOOB question can you put ac in side a 1994 civic hatchback cx
Old Apr 6, 2007 | 04:10 PM
killingtwobirds's Avatar
Default NOOB question can you put ac in side a 1994 civic hatchback cx
can you put ac in side a 1994 civic hatchback cx?
Old Apr 6, 2007 | 04:15 PM
anavrin351's Avatar
Default Re: NOOB question can you put ac in side a 1994 civic hatchback cx (killingtwobirds)
u can add ac in a dx so u should beable to in a cx if thats what u mean by putting it inside
1999mrsi's Avatar
69.225.89.89
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killingtwobirds &raquo;</TD></TR><TR><TD CLASS="quote">can you put ac in side a 1994 civic hatchback cx? </TD></TR></TABLE>
yes you can....
but are you looking for a diy?
is that what your real question is...?
it will require a lot of fabricating unless you get a new dash and get all parts needed to hook a/c..
Old Apr 6, 2007 | 05:43 PM
yah what kind of this do i need to install ac in the 1994 cx hatchback and how much will it cost me and where can i get a dash??
Old Apr 7, 2007 | 03:01 AM
what kind of parts i need to make my ac work and how much is it going to cost me??
Old Apr 7, 2007 | 03:44 AM
tampajason's Avatar
thats weird. I had a cx hatcback and it had a/c. Was it factory installed from 95+?
Old Apr 7, 2007 | 03:59 AM
JSPECSIR's Avatar
Default Re: (sxecrow)
http://www.hondaautomotiveparts.com they have an a/c kit, its supposed to come w/ everything. youll have to look around on there to find it. i dont think it was very expensive either.
Old Apr 7, 2007 | 06:07 AM
h2392si's Avatar
Default Re: (JSPECSIR)
Yes you can. You can do pretty much anything to a honda with the right parts and $$$. Try to do it yourself and post pics.
Old Apr 7, 2007 | 10:47 AM
CivicSpoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sxecrow &raquo;</TD></TR><TR><TD CLASS="quote">thats weird. I had a cx hatcback and it had a/c. Was it factory installed from 95+? </TD></TR></TABLE>
It was an option, at least for the '92-'95 Civics; my '94 CX has A/C.
Old Apr 7, 2007 | 11:10 AM
philosofy1's Avatar
Default Re: NOOB question can you put ac in side a 1994 civic hatchback cx (1999mrsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999mrsi &raquo;</TD></TR><TR><TD CLASS="quote">
yes you can....
it will require a lot of fabricating unless you get a new dash and get all parts needed to hook a/c..</TD></TR></TABLE>
wow, you really don't know much about anything!
yes you can install a a/c system in your 94 cx. it is a straight bolt on affair with NO FABRICATION!
you will want to get an a/c system from a 94-95 civic, being that 94-95 systems are r134, prior to 1994 was the r12 system. as long as it's from 94-95 you will have no problems.
i bought mine used on ebay either from
http://www.hondaacurasalvage.com/
or from
discovery auto parts.
mine came off of a 95 ex, ran me $350 w/shipping. everything came included to do the install.
good luck.
Old Apr 7, 2007 | 11:22 AM
SluggishDA's Avatar
yes u can put ac in it
Old Apr 7, 2007 | 12:26 PM
this is all i need to make my ac start to work???? oh yeah the car does not have the ac button do i also have to buy that?
will this kit work??? is that all i need?? thanks everyone for your help. http://www.hondaautomotivepart...R+KIT
Old Apr 7, 2007 | 12:48 PM
philosofy1's Avatar
Default Re: (killingtwobirds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killingtwobirds &raquo;</TD></TR><TR><TD CLASS="quote">this is all i need to make my ac start to work???? oh yeah the car does not have the ac button do i also have to buy that?
will this kit work??? is that all i need?? thanks everyone for your help. http://www.hondaautomotivepart...R+KIT</TD></TR></TABLE>
i really don't know exactly how that works. you might want to call and find out. they do sell a kit, but the kit i'm thinking of it to convert the r12 system (found on civic's prior to 1994) to the r134 system.
looking at the price $560, seems alittle on the low side. a compressor alone will run you about $300, evaporator $150, condensor $200, drier $40.
and these are for all new parts, which the dealer only sells new parts.
Old Apr 7, 2007 | 01:08 PM
ill try call and find out.. but this is all i need to make my ac start working right?
pinoy85
Mar 31, 2013 09:56 AM
csp39
17
May 26, 2012 06:17 AM
teeho
Oct 23, 2007 06:17 AM
M75
May 2, 2005 11:52 PM
pink hatchy
Aug 18, 2004 09:13 PM
