Question about bearing clearances...
Old Apr 6, 2007 | 01:52 PM
geebs's Avatar
Default Question about bearing clearances...
I mearsured all my clearances for my main bearings they're all roughly 0.038 mm.. i know its in spec by a lil 0.042mm.. should i try to put a half of the next size up and see what i get? or do you think that it should be okay? looking for opinions...
Old Apr 8, 2007 | 05:46 PM
geebs's Avatar
Default Re: Question about bearing clearances... (geebs)
bump for some opinions..
Old Apr 8, 2007 | 06:11 PM
Luserkid's Avatar
Usually you read into inches over mm. But this one converter said your in .0015'' which is very good.
Old Apr 9, 2007 | 05:40 AM
geebs's Avatar
Default Re: Question about bearing clearances... (Luserkid)
I prefre MM because theres less 0's... i duno why.. heh .. the honda manual uses MM but also has the inches ..
1988dxsedan
Engine Machining & Assembly
12
Nov 22, 2015 06:28 PM
neonkid
Oct 24, 2012 01:57 PM
hatchbackjdm
Feb 25, 2006 04:16 PM
tgreaves
Jan 22, 2004 05:52 PM
