Fuel pump?
all right guys I have a 91 integra with fuel problems and I have done everything to this cars fuel syestem except change the pump I wanted to know if there was a way to rebuild the fuel pump because I have no money at all and gott to go to a few job interviews so any help will work.
cee the problem is I have no cash and I need my car to get some money I guess I could sell 10 gallens thats in my tank 4 about 20 as high as gas is out here
First About 2 weeks ago I noticed my car stalling and shuting off engine light came on ecu gave me a code 43 fuel syestem so I started searching 4 leaks nothing then I changed the fuel filter. It started running worse so about 3 days ago my car spettered like It had been and shut offso I had 2 push it home and it wouldnt start all three days so yesterday I started taking off the powersterring and a/c pieces and for ***** and giggles tried to start her up and walla it started but idels and rougher than it did when it died + I got fired early last month and have no income so I just need to get this car running decent long enough to find a job and get her fixed
so when you said you did a complete over haul on the system except the pump, did you also change the injectors?...and what about the fuel rail?
might be something else, fuel pumps last along time before something gives in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg »</TD></TR><TR><TD CLASS="quote">There is also a Main Fuel Relay. MFR</TD></TR></TABLE>
forgot about the relays
