Need Help With Power Steering System of a 99'SI
Old Apr 5, 2007 | 10:39 PM
a10secstreetcar's Avatar
Default Need Help With Power Steering System of a 99'SI
Hey,
I took my Power Steering System off my 99' SI so I can install my Peakboost Top mount Setup. My Question is I Dont want to do it Wrong. I have search and found Nothing. I see how to loop the system so everything stays lube,But How do I make sure that its got enough fluids in the power steering rack to be good? Should I just top it off with power steering fluid where I loop the hoses?
Thanks!
Old Apr 7, 2007 | 05:37 AM
jz98ctr's Avatar
Default Re: Need Help With Power Steering System of a 99'SI (a10secstreetcar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a10secstreetcar &raquo;</TD></TR><TR><TD CLASS="quote">Hey,
Thanks! </TD></TR></TABLE>
you NEED to send me your power steering pump and lines...like last week lol
pm me if you wanna sell or haven't sold them parts yet!!!!
Old Apr 7, 2007 | 10:28 AM
arc_55's Avatar
What i would do is just block off the lines at the rack and then run a line up to your resivior so that the powersteering system is always submerged in fluid. This way you can still check your power steering system for clean fluid and can still flush the system out. Powersteering fluid that has been exposed to heat or that is dirty will rise and this allows you to suction out the resivior and add new fluid. I know this is probably not the best system, but i think its as close as you can get before swithcing to a manual rack. Looping the lines is another option, but not entirely good for the system.
Old Apr 7, 2007 | 04:02 PM
jz98ctr Pm sent!
arc_55 True on that. Just want to make sure I do it right.Dont want to be doing 130mph at the track and my Steering stops working. LOL
Old Apr 10, 2007 | 04:59 PM
jz98ctr's Avatar
you got pm
Old Apr 10, 2007 | 06:01 PM
inspyral's Avatar
I have mine looped with an added breather/reservoir at the top of the loop. No problems for over 4 years or so. A guy named Padawan here on HT used to sell a kit that included all the lines, fittings, and breather/reservoir. That's the one I'm using. I keep enough fluid to come up to the bottom of the reservoir, and it works great.
Old Apr 11, 2007 | 08:44 AM
Padawan's Avatar
Darth ModerVader
Default Re: (inspyral)
Glad to read that the kit is working well for you, inspyral.
Old Apr 12, 2007 | 05:16 AM
jz98ctr's Avatar
Padawan
Old Apr 12, 2007 | 08:13 PM
Power Steering Sold to jz98ctr Thanks!
Old Apr 12, 2007 | 08:31 PM
arc_55's Avatar
Are you going to get a kit? Or are you going to retro fit something yourself?
Old Apr 13, 2007 | 05:27 AM
jz98ctr's Avatar
Default Re: (a10secstreetcar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a10secstreetcar &raquo;</TD></TR><TR><TD CLASS="quote">Power Steering Sold to jz98ctr Thanks!</TD></TR></TABLE>
score!
Old Apr 13, 2007 | 09:21 AM
Im going to Buy a Kit..
Old Apr 13, 2007 | 09:22 AM
Not sure where tho!
Old Apr 13, 2007 | 02:01 PM
pdiggitydogg's Avatar
padawn's kits are very nice
Old Apr 16, 2007 | 05:09 PM
jz98ctr's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">padawn's kits are very nice</TD></TR></TABLE>
a10secstreetcar
Apr 6, 2007 12:09 PM
egmatt93
11
Mar 10, 2007 09:35 AM
1994IntegraRS
Aug 18, 2004 05:19 PM
dieselboy
Jan 17, 2002 09:46 PM
