stock shocks....
Old Apr 5, 2007 | 08:00 PM
mysicivic1991's Avatar
Default stock shocks....
i have coilovers with no shocks, would it be fine to put it on my stock shocks? for a 91 civic si ef??
Old Apr 5, 2007 | 08:09 PM
RockWolf's Avatar
Default Re: stock shocks.... (mysicivic1991)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mysicivic1991 &raquo;</TD></TR><TR><TD CLASS="quote">i have coilovers with no shocks, would it be fine to put it on my stock shocks? for a 91 civic si ef??</TD></TR></TABLE>
yes if you are ready to sacrifice confort. Also if droped too much your stock shocks wont last long. By the way what kind of coil overs do you have?
Old Apr 5, 2007 | 08:14 PM
freakystyley_73's Avatar
I did that and I'm going back to my stock springs tomorrow. Don't do it. It's a waste of time, and it can actually make your vehicle dangerous. It's so bouncy that I often catch air (as in my body from the seat, not the car) when i hit bumps or divets at high velocities. It's extremely distracting and you can easily lose control of the car.
Old Apr 5, 2007 | 08:15 PM
Default Re: stock shocks.... (RockWolf)
i have a no brand coilovers i got it for 90 bucks i dont know if i should put it on with the my stock shocks.
Old Apr 5, 2007 | 08:17 PM
Default Re: (freakystyley_73)
Should i just get springs or will it be the same??
Old Apr 5, 2007 | 08:21 PM
RockWolf's Avatar
Default Re: (mysicivic1991)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mysicivic1991 &raquo;</TD></TR><TR><TD CLASS="quote">Should i just get springs or will it be the same??
Usualy coil over already have springs. are you telling us that you just have the screw type adjustment?
Aftermarket shocks would be a thing to consider if you want to lower your car and use coil overs.
Don't forget,the more money you put in your suspension, the more you will feel good about your investment.
Old Apr 5, 2007 | 08:27 PM
Default Re: (RockWolf)
so do you think if i plan to lower my car, i should change my shocks and add the springs? it wouldnt be worth it with the stock shocks right?
Old Apr 5, 2007 | 08:36 PM
RockWolf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mysicivic1991 &raquo;</TD></TR><TR><TD CLASS="quote">so do you think if i plan to lower my car, i should change my shocks and add the springs? it wouldnt be worth it with the stock shocks right?</TD></TR></TABLE>
well actualy its what i am doing right now. I bought some tokico illuminas shocks and lowering spring set. doh i am not a big fan of coil overs.
The difference in the stock springs and lowered springs is that since there is not the same space for movement, usualy the springs are stronger. Having a stronger spring rate causes it to save the same amount of energy as a normal spring in a shorter space. and since the stock shocks are only able to absorb a fraction of the amount on a distance, the suspension deploys a little more. That what causes the bounce. Having better shocks will prevent that return of energy.
In short: no it wont be worth at all.
Old Apr 5, 2007 | 08:41 PM
.Grimace's Avatar
footwork mastery
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakystyley_73 &raquo;</TD></TR><TR><TD CLASS="quote">I did that and I'm going back to my stock springs tomorrow. Don't do it. It's a waste of time, and it can actually make your vehicle dangerous. It's so bouncy that I often catch air (as in my body from the seat, not the car) when i hit bumps or divets at high velocities. It's extremely distracting and you can easily lose control of the car.</TD></TR></TABLE>
you just lost your talking privlages... for stupid answers
taimysho0
Aug 17, 2008 05:12 PM
Asway
70
Dec 13, 2006 08:12 PM
everlast
Aug 24, 2004 05:50 AM
SweetSnowGurl
May 27, 2004 05:48 PM
93CX
12
Jul 13, 2003 12:59 PM
