oil pan bolt problem
Old Apr 5, 2007 | 05:39 PM
nonvteclude's Avatar
Default oil pan bolt problem
ok guys this has been a really bad day, but to get to the point i was putting the last bolt in for the oil pan and it decided to strip the threads out of the block. so i drilled dapped and put a heli-coil in, but the block stripped again but this time around the coil. any ideas on how i can fix this? should i drill it for a 12 mil? any help would be great
Old Apr 5, 2007 | 05:51 PM
Rosko's Avatar
Default Re: oil pan bolt problem (nonvteclude)
holy **** dude quit doin that!!
next size up from 6mm would be an 8mm, dunno if you could make theat work or not.
Old Apr 6, 2007 | 02:35 PM
Default Re: oil pan bolt problem (Rosko)
bump for suggestions
sleeperhonda
10
Aug 20, 2013 08:18 AM
Spithead051
Dec 17, 2008 03:53 PM
kaychi
Jul 9, 2008 12:10 PM
ombl4
May 10, 2007 01:42 PM
