Brake conversion?
Old Apr 5, 2007 | 05:24 PM
SpeedoKing's Avatar
Default Brake conversion?
i have a 99 EX and i would like to put discs in the bake what is the best way to go about this and what is the price range that im looking at?
Old Apr 5, 2007 | 05:39 PM
doood's Avatar
been there done that
Default Re: Brake conversion? (SpeedoKing)
94-01 integra rears are straight bolt on's
Old Apr 5, 2007 | 06:58 PM
amej8's Avatar
Or 99-00 SI's.
If you junkyard it or find someone parting out their Teggy/SI here, shouldn't cost you more than a few hundred (shipping would be a bitch).
Old Apr 5, 2007 | 07:59 PM
kaiba's Avatar
Just make sure you get 99-00 si parking cables.
Old Apr 10, 2007 | 08:10 PM
SpeedoKing's Avatar
Default Re: Brake conversion? (JJSpecTuning)
where did you find the brake conversion and how hard is it to put on?
Old Apr 10, 2007 | 08:19 PM
SOHC4life 96's Avatar
Check in the classifieds that is where I got mine for $175. If you have never done any car work past changing oil/spark plugs/wires it will probably take you 5-8 hours. Depends on how well you are at following directions and if you have any help.
Once you do it, get your car aligned. The back of you car will be way out of wack if you don't.
Old Apr 10, 2007 | 08:23 PM
bmoua's Avatar
check these diy out first bro....
https://honda-tech.com/zerothread/642479
dont listen to kaiba, 94-01 teg ebrake cables will bolt right up. Either 4door or 2door theres no difference....
Old Apr 10, 2007 | 09:00 PM
SpeedoKing's Avatar
Default Re: (bmoua)
is there a kit that i can buy that will convert the dumbs into discs, or do i have to buy a new rear axle?
Old Apr 10, 2007 | 09:12 PM
pkdog167's Avatar
Default Re: (SpeedoKing)
Yes fastbrake make a kit, I think it's like....$600?? with all brand new parts. Just get the one off integra or si. And I don't think civic have a rear axle..
Old Apr 12, 2007 | 01:42 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedoKing &raquo;</TD></TR><TR><TD CLASS="quote">is there a kit that i can buy that will convert the dumbs into discs, or do i have to buy a new rear axle? </TD></TR></TABLE>
as long as you get the complete rear trailing arms/brake assembly's from a teg it will bolt on and you'll have rear disks.
Old Apr 12, 2007 | 02:14 PM
EL Vap133's Avatar
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">check these diy out first bro....
dont listen to kaiba, 94-01 teg ebrake cables will bolt right up. Either 4door or 2door theres no difference....</TD></TR></TABLE>
madmanmaigret
Jul 24, 2007 05:59 AM
Curbow_USMC
Mar 2, 2007 08:25 PM
6SPD_EK
Apr 10, 2004 09:19 AM
