Brake conversion?
Brake conversion?
i have a 99 EX and i would like to put discs in the bake what is the best way to go about this and what is the price range that im looking at?
Re: Brake conversion? (SpeedoKing)
Check in the classifieds that is where I got mine for $175. If you have never done any car work past changing oil/spark plugs/wires it will probably take you 5-8 hours. Depends on how well you are at following directions and if you have any help.
Once you do it, get your car aligned. The back of you car will be way out of wack if you don't.
check these diy out first bro....
https://honda-tech.com/zerothread/642479
dont listen to kaiba, 94-01 teg ebrake cables will bolt right up. Either 4door or 2door theres no difference....
Re: (SpeedoKing)
Yes fastbrake make a kit, I think it's like....$600?? with all brand new parts. Just get the one off integra or si. And I don't think civic have a rear axle..
been there done that
Re: (SpeedoKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedoKing »</TD></TR><TR><TD CLASS="quote">is there a kit that i can buy that will convert the dumbs into discs, or do i have to buy a new rear axle? </TD></TR></TABLE>
as long as you get the complete rear trailing arms/brake assembly's from a teg it will bolt on and you'll have rear disks.
Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">check these diy out first bro....
dont listen to kaiba, 94-01 teg ebrake cables will bolt right up. Either 4door or 2door theres no difference....</TD></TR></TABLE>
6SPD_EK
04-10-2004 09:19 AM
