Will this cause my cf hood to crack?
Old Apr 5, 2007 | 04:45 PM
alacard's Avatar
Default Will this cause my cf hood to crack?
I'm about to install mugen hood pins on my cf hood. Just want to make sure I do it right. I searched and read in one of the threads that if you use the screws for the top part of the hood pins (the 3 or so on each side) it will cause the hood to spiderweb crack. Is this true? That same post said to use rivets. What is, in fact, the correct way to do it?
Old Apr 5, 2007 | 04:48 PM
JDM-EJ1's Avatar
Default Re: Will this cause my cf hood to crack? (alacard)
When I bought my CF hood (used from a really good guy here on HT), it was already predrilled for Sparco pins. The peice that was connected to the face of the hood was riveted in. There wasn't any cracking around it at all. The condition of the hood was mint.
Old Apr 5, 2007 | 04:58 PM
BlueIntegraBoy's Avatar
I think the process of screwing in the screw causes the clear to spiderweb.
Old Apr 5, 2007 | 06:18 PM
alacard's Avatar
So basically I need to go buy a rivet gun to be able to put these in?
Old Apr 6, 2007 | 02:44 AM
Default Re: (alacard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">So basically I need to go buy a rivet gun to be able to put these in?</TD></TR></TABLE>
Don't really know any other way of putting in rivets.
Old Apr 6, 2007 | 04:55 PM
alacard's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Don't really know any other way of putting in rivets. </TD></TR></TABLE> Use your teeth? haha. picked one up today, should be putting the pins in tonight if all goes well *crosses fingers for no spiderweb cracking*
Old Apr 6, 2007 | 05:02 PM
JCracer723's Avatar
i wouldnt use those gay screws.. nor rivets ( since i dont got a rivet gun )
get some nice stainless steel socket button head bolts and nuts/washers @ local hardwear or online http://www.boltdepot.com
Old Apr 6, 2007 | 05:16 PM
Luserkid's Avatar
Put either masking tape or duct tape over the area you want to work on, that will help pervent any cracks or spiderwebbing. (Ducttape is just harder to clean)
Old Apr 6, 2007 | 07:36 PM
tampajason's Avatar
I'd cover the hood in tape where you're going to drill, use a unibit, and go slowly. Shouldn't be a problem if you take your time.
Old Apr 7, 2007 | 11:30 PM
alacard's Avatar
alright thanks, i hadn't thought about tape. Just used the tape idea for my sidemarkers, don't know why i didnt think about it for the hood pins.
Old Apr 7, 2007 | 11:32 PM
SiYouLater's Avatar
Use a nice drill bit; one that isn't dull.
Old Apr 7, 2007 | 11:35 PM
Vintech's Avatar
Default Re: (SiYouLater)
For drilling, i would say<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sxecrow &raquo;</TD></TR><TR><TD CLASS="quote">I'd cover the hood in tape where you're going to drill, use a unibit, and go slowly. Shouldn't be a problem if you take your time. </TD></TR></TABLE>
when you install pins or whatever, washers will help you distrubute the pressure to avoid cracking the hood
Old Apr 8, 2007 | 12:06 AM
CarbonEGG's Avatar
Default Re: (Vintech)
When I got my mugen hood pins installed the guy used a drill bit thats specially used for carbon fiber so prevent it from cracking. All i know is that it worked.
He used a regular DeWalt drill like the one in the pic. Dont know what the bit was. Sorry
Old Apr 8, 2007 | 12:25 AM
spork motorsports's Avatar
* B A N N E D *
Default Re: (CarbonEGG)
simple be like me and dont run pins and prey for the day that the hood does not come flying up on you
lickety_britches
Jul 29, 2008 08:14 AM
Devo94ac
Mar 9, 2006 05:47 AM
OoHiTzToMMy
29
Dec 11, 2005 03:43 PM
Uneekpinoysk8er
12
Apr 23, 2003 10:32 PM
Gusto222
Feb 26, 2003 02:50 PM
