Problem with interior light on 98 Civic?
Old Apr 4, 2007 | 04:27 AM
rhgindc's Avatar
Default Problem with interior light on 98 Civic?
I just purchased a 98 Civic HX and the interior light works (on the continuous 'on' position) but when the switch is in the middle the light is supposed to come on when I open the driver or passenger door but it doesn't come on. Does anyone know what might be wrong? Is there a simple fix? Thanks
Old Apr 4, 2007 | 04:50 AM
justlook's Avatar
Default Re: Problem with interior light on 98 Civic? (rhgindc)
bump for the same problem.
Old Apr 4, 2007 | 05:26 AM
JDM_EK_wanabe's Avatar
if you have an aftermarket cd player and dont have the stock radio that is your problem, for some reason they put the dome light control in the radio, along with security system too if you happen to have it
Old Apr 4, 2007 | 06:48 AM
ifIexplode's Avatar
I have an aftermarket Head unit and my dome light works in the middle for when its on when the door is open...
Old Apr 4, 2007 | 06:54 AM
kaiba's Avatar
Old Apr 4, 2007 | 06:57 AM
jibs's Avatar
Default Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_wanabe &raquo;</TD></TR><TR><TD CLASS="quote">if you have an aftermarket cd player and dont have the stock radio that is your problem, for some reason they put the dome light control in the radio, along with security system too if you happen to have it</TD></TR></TABLE>
if you have a 96-98 then your factory head unit is probably hooked up and buried somewhere behind the dash...
You need the factory radio for dome light, security and keyless
Old Apr 4, 2007 | 07:08 AM
pdiggitydogg's Avatar
Actually, you can wire the dome light up to work without the factory keyless - you just have to slice a couple wires from the green harness.
Old Apr 4, 2007 | 07:11 AM
robble36's Avatar
Default Re: (pdiggitydogg)
just rip that crap out it is soo dim well at least mine is and its not the bulbs because the bulbs i replaced it with sucks also.
Old Apr 4, 2007 | 08:00 AM
mines bight...i have a ricer hyper white in there though
Old Apr 5, 2007 | 10:20 PM
n8guy's Avatar
Default Re: (jibs)
How can one get a factory head unit? I've got an aftermarket stereo/CD player, but I'm not thrilled with it either. Could I replace it with a stock unit? Where does one find one of these for a 98 Civic HX?
Old Apr 5, 2007 | 10:53 PM
nighttrain33's Avatar
Default Re: (n8guy)
I may still have mine If you want I can look for it at my parents' house.
-Shane
Old Apr 5, 2007 | 10:56 PM
Default Re: (n8guy)
Edit, it may be in my basement. I will look tomorrow and let you know
-Shane
Old Apr 5, 2007 | 11:21 PM
ridin98civic's Avatar
Default Re: (jibs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jibs &raquo;</TD></TR><TR><TD CLASS="quote">
You need the factory radio for dome light, security and keyless</TD></TR></TABLE>
wrong, i have a 98ex, both headunit and the cd slave are removed completely, aftermarket headunit installed and no other mods done to any wiring harness. my domelight works on the door setting
Old Apr 5, 2007 | 11:24 PM
MonkeyBoy668's Avatar
I always try to first rule out the simple stuff when diagnosing problems on ~10 year old cars... are you sure your door switches are working?
The door switches probably work based on passing current when the door's open, so you'd need to unscrew the switch and momentarily bridge the connectors. If the light still stays off, the switch is fine and you can move onto the more difficult causes.
While it's unlikely that both switches are dead, you never know what the previous owners did... they could've just not replaced the switches, eventually they'd both be dead.
This is why I like being the only owner of my 10 year old car. Far fewer mysteries.
Old Apr 6, 2007 | 04:57 AM
jibs's Avatar
Default Re: (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">
wrong, i have a 98ex, both headunit and the cd slave are removed completely, aftermarket headunit installed and no other mods done to any wiring harness. my domelight works on the door setting</TD></TR></TABLE>
Then you are the exception. There are already numerous threads on this - search.
Old Apr 6, 2007 | 07:56 AM
rhgindc's Avatar
Default Re: (nighttrain33)
Shane (nighttrain33),
Did you find the factory radio? What features are on it? How much are you asking for it?
Thanks,
Ray
Old Apr 6, 2007 | 08:07 AM
Default Re: (rhgindc)
Sure did find it. The crappy thing about it is it is just AM/FM since there was a CD changer hooked to it. I do also still have the changer if you are interested. And as far as the radio is concerned, I wouldn't want more than $20.
-Shane
Old Apr 7, 2007 | 03:15 AM
rhgindc's Avatar
Thanks Shane. I think I'll have to pass. I guess I'll have to sit in the dark while listening to my CD's on my aftermarket unit!
Old Apr 7, 2007 | 03:18 AM
rhgindc's Avatar
PDIGGITYDOGG,
Could you please give me more specific details how to wire it so I can get the light to turn on in the middle position with the door open?
I'm not super savvy when it comes to electrical wiring. Computers I know. Wiring and electrical I'm afraid not. So any detailed help you could provide would be greatly appreciated.
Old Apr 7, 2007 | 04:06 AM
JSPECSIR's Avatar
there is a green keyless entry plug behind your radio. to make the domelight work you must jumper the lt. green/red wire with the lt.green/black wire and this will complete the circuit. those of you that have aftermarket decks and your light still works, its because the person putting it your radio jumped it already. there are no fluke cases it has to be jumped for the light to work. hope this helps.
allvtecyo
Jul 15, 2014 01:11 PM
redtegy
11
Feb 1, 2013 06:13 PM
EKing
Audio / Security / Video
Dec 24, 2009 05:42 AM
ZanderGTS
25
Jun 29, 2007 06:54 PM
8200RPM
11
Oct 27, 2005 06:47 AM
