overheat problem.........Help
Old Apr 3, 2007 | 09:04 PM
Donhonda84's Avatar
Default overheat problem.........Help
I have a eg with a d16 and up until recently its been overheating.. I got out of my car the other night and saw coolent on the ground and mist coming from the coolent container. I checked it out and there was no broken hoses or anything. The coolent was boiling and coming out from the top of the container.. Are there any idea what it can be?
Old Apr 3, 2007 | 09:21 PM
sol2hatch's Avatar
Default Re: overheat problem.........Help (Donhonda84)
bad thermostat possibly. Let car get warm, then check the upper hose to see if its warm, if its not, the thermostat is not working, and needs to be replaced.
Old Apr 3, 2007 | 09:36 PM
Donhonda84's Avatar
I check it and its not my thermostat but i saw he fan didn't come on at all. Does anyone know what might be wrong with the fan..??
Old Apr 3, 2007 | 09:41 PM
sol2hatch's Avatar
the fan wont cause that problem. Are you sure its not your thermostat? how did you rule it out?
Old Apr 3, 2007 | 09:48 PM
Donhonda84's Avatar
Default Re: overheat problem.........Help (sol2hatch)
I left the engine running until it heated up... and all the hose where warm...
Old Apr 4, 2007 | 02:24 AM
rickeg6's Avatar
i had that problem, what i did was i by-pass my radiator fan to my ignition with a fuse so when i turn on the key the fan turn on. running the fan at all time..
Old Apr 4, 2007 | 04:49 AM
h2392si's Avatar
Default Re: (rickeg6)
Try the fan temp switch, thermostat, radiator cap, bleed the system, etc. Also the realy in the fuse box for the fan. This has been covered many times. Next time try a search, there are some great threads on how to fix it.
Old Apr 4, 2007 | 05:21 AM
95ProjectEJ1's Avatar
Default Re: (h2392si)
Jump the fan... run two wires from your battery terminals (1 pos. 1 neg) to the connector on the fan shroud. Unplug it and connect... remember the prong that is connected to the black wire will be your ground. Once you have the wires connected the fan should come on if it is working.
Old Apr 4, 2007 | 05:59 AM
1.6vx's Avatar
fan temp censor thats your problem i had the same problem with my lx. Censor sits on top of your thermostat. Quick fix run a direct switch to your fan so you can turn it on when your engine starts to warm up. untill you can get another censor.
Old Apr 4, 2007 | 08:36 PM
Donhonda84's Avatar
does anyone know how much it would cost to replace the sensor?
MyRed98Civ
Jan 11, 2014 06:51 PM
Shade93
Apr 13, 2010 01:15 PM
jkalex05
Aug 22, 2009 07:02 AM
SpoonREVS
Jan 24, 2006 05:42 PM
hybrider
Jul 23, 2002 08:21 AM
