How to remove these studs?
Old Apr 3, 2007 | 04:59 PM
Surebang's Avatar
Default How to remove these studs?
Any body know how to remove or break the studs. I accidently over torqued and now i cant get them off. Thanks guys.
Modified by Surebang at 10:45 AM 4/4/2007
Old Apr 3, 2007 | 05:13 PM
messeduprex's Avatar
Default Re: How to remove these studs? (Surebang)
muscles they cant be on there that tight i have broken many valve cover bolts using an small 1/4 rachet
Old Apr 3, 2007 | 05:20 PM
Luserkid's Avatar
Default Re: How to remove these studs? (messeduprex)
Snap it off then take the valve cover off and take the stud out and replace it.
Old Apr 3, 2007 | 05:22 PM
envee's Avatar
pb blaster. if thats doesn't work bfh.
Old Apr 3, 2007 | 05:23 PM
Surebang's Avatar
Tried breaking it with a hammer and flathead. Wouldnt break.
Old Apr 3, 2007 | 05:28 PM
Surebang's Avatar
forgot to mention it the cap spins freely so i stripped the thread.
Old Apr 3, 2007 | 05:30 PM
xhatchracerx's Avatar
Default Re: (Surebang)
try using a screw driver to push up the nut while unscrewing it with a wrench
Old Apr 3, 2007 | 05:40 PM
VRD^don's Avatar
Default Re: (xhatchracerx)
dremel it off
Old Apr 3, 2007 | 05:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surebang &raquo;</TD></TR><TR><TD CLASS="quote">forgot to mention it the cap spins freely so i stripped the thread.</TD></TR></TABLE>
get a bolt out set from sears
Old Apr 3, 2007 | 06:43 PM
Surebang's Avatar
Default Re: (messeduprex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex &raquo;</TD></TR><TR><TD CLASS="quote">get a bolt out set from sears </TD></TR></TABLE>
Never knew there was such a thing.
Old Apr 3, 2007 | 06:50 PM
yeah it looks like a socket but its spireled on the inside to grip the bold ill get a pic for you if i can
here you go!
Old Apr 3, 2007 | 06:54 PM
Surebang's Avatar
Still dont understand how it works.. I'll try google.
Old Apr 3, 2007 | 07:00 PM
you just put it on the nut or bolt and turn it like you are going to lossen it and it digs into the nut or bolt and takes it off you will have to replace the bolts after you get them off
Old Apr 3, 2007 | 07:06 PM
Surebang's Avatar
But if the nut spins freely on the bolt how would it work.. *scratches head*
Old Apr 3, 2007 | 07:10 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Why nead a bolt extractor if the nut is only the size of my toe nail.
Old Apr 3, 2007 | 07:11 PM
ow nvm. cut it off an get a new stud. lol. Or get a knife an wedge it under neath the nut an try to twist the nut off.
Old Apr 3, 2007 | 07:15 PM
NVMYSTI's Avatar
Just do like xracerhatchx said and use a flat head screw driver to pry up on the bottom of the nut while you use a ratchet to unscrew the nut
Old Apr 3, 2007 | 07:18 PM
LOL i said a knife, i got to stay away from these kind of forums when im drunk.
Old Apr 3, 2007 | 07:32 PM
Surebang's Avatar
Default Re: How to remove these studs? (NVMYSTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVMYSTI &raquo;</TD></TR><TR><TD CLASS="quote">Just do like xracerhatchx said and use a flat head screw driver to pry up on the bottom of the nut while you use a ratchet to unscrew the nut</TD></TR></TABLE>
Yea, I was gonna try that when i get off work tmmrw afternoon. At work right now so cant do it here. I was just wondering if there was anymore options.
gsrswap
18
May 7, 2007 11:06 AM
cifer6425
Feb 19, 2007 04:44 AM
Esdelota
10
Oct 18, 2006 05:50 AM
Jdmglenn
May 5, 2005 09:40 AM
Beave0101
Aug 24, 2003 12:16 PM
