valve cover bolts
valve cover bolts
i tryed to take my valve cover of and paint it and the nut on the left front will not come off. any help would be great. its a b series if that matters.
Re: (gsrswap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrswap »</TD></TR><TR><TD CLASS="quote">its not stuck or rusted. it just turns and turns without coming off.</TD></TR></TABLE>
stripped. in this case try yanking it out with dikes?
Ek Forever y0!
Re: (gsrswap)
If it's not stripped, tighten back down some of the other bolts.
With 3 off and the 4th one all the way tight, it's going to be harder to get off. You should have loosened them all progressively.
If that doesn't work buy some pb blaster or liquid wrench.
Re: (gsrswap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrswap »</TD></TR><TR><TD CLASS="quote">can the stud coming out of the head be replaced?</TD></TR></TABLE>
yes, you can buy a new stud to replcae it.
You may have over tighten last time and stripe or broke the stud.
Re: (slvrlude)
i agree with the guy who last posted, jp, i would just do what it akes to get that nut off, and yes you can replace it with a new one. its pretty easy.
remove all the other bolts and pull up on the valve cover while unscrewing the one stuck nut. chances are the stud is junk and yes it is easily replaced just get it from honda
