How to remove these studs?
Any body know how to remove or break the studs. I accidently over torqued and now i cant get them off. Thanks guys.
Modified by Surebang at 10:45 AM 4/4/2007
Re: (Surebang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surebang »</TD></TR><TR><TD CLASS="quote">forgot to mention it the cap spins freely so i stripped the thread.</TD></TR></TABLE>
get a bolt out set from sears
Re: (messeduprex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex »</TD></TR><TR><TD CLASS="quote">get a bolt out set from sears </TD></TR></TABLE>
Never knew there was such a thing.
Re: (Surebang)
you just put it on the nut or bolt and turn it like you are going to lossen it and it digs into the nut or bolt and takes it off you will have to replace the bolts after you get them off
Re: How to remove these studs? (Surebang)
Just do like xracerhatchx said and use a flat head screw driver to pry up on the bottom of the nut while you use a ratchet to unscrew the nut
Re: How to remove these studs? (NVMYSTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVMYSTI »</TD></TR><TR><TD CLASS="quote">Just do like xracerhatchx said and use a flat head screw driver to pry up on the bottom of the nut while you use a ratchet to unscrew the nut</TD></TR></TABLE>
Yea, I was gonna try that when i get off work tmmrw afternoon. At work right now so cant do it here. I was just wondering if there was anymore options.
Esdelota
10
10-18-2006 05:50 AM
