ALL kinds of stuff. b16,b18,Da,eg
oil cooler - $15
sohc tb- $10 - missing MAP
(2) b series tb's - $20
obd1 gsr and obd2 gsr Tb's - $30
vtec spark plug covers (2)- $15
b16 block gaurd "autotechnics"- $40
obd1 b17a ignition coil - $25
obd2 (b-series vtec)bare dizzy- (missing plug)- 10
-came off a running motor but was put in an obd1 car so i used it for parts. shaft is perfect
obd1 vtec dizzy - (2) - $50 ea
sohc fuel rail - $5
b series fuel rails - $15 ea
eg hatch/coupe corners - $10
1992-1995 civic si sunroof assembly- 50 dollars (cracked glass)
B series LSD half shaft- $30
ctr crank pulley $30/ stock b series- $5
Blox b18c intake Manifold- $75
b16a block and crank- $50
HASPORT (B) cable tranny to Eg chasis mount- $75
92gsr cluster - $40
ecu obd0 b16 $50 / ls - $25
sohc fuel rail - $5
.b16a block and crank- $50
92gsr cluster - $40
Contender25
Aug 16, 2007 07:14 PM
