OBD-1 Dizzy Into a B20B
Old Jan 2, 2013 | 12:47 PM
woodenchef's Avatar
Default OBD-1 Dizzy Into a B20B
My 1991 Civic wagon has been converted to OBD-1.
Will a OBD-1 Distributor off a ls integra fit my OBD-2 B20B. I was planning on buying the Rywire OBD-1 Wiring harness. So can I just get a OBD-1 Distributor for my B20B, and the Rywire OBD-1 plug should just plug right in?
Same goes for the alternator, injectors, etc? Everything has to stay OBD-1 if my car is wired for OBD-1 right?
Old Jan 2, 2013 | 02:15 PM
EpHatchy's Avatar
Default Re: OBD-1 Dizzy Into a B20B
distributors can be used between any motor b-series as long as the mounting is the same.vtec vs nonvtec.if your using the dist on the b20 which is obd2 just buy a dist jumper to convert it to obd1 which is what your car is.
Old Jan 2, 2013 | 07:11 PM
woodenchef's Avatar
Thanks. Thing is when I bought my B20b from the JDM store in was just the head and block no external parts. So basically I was most likely going to go to the junkyard and get the parts. Would it be best to just stick with OBD-1 parts? Since everything should be just straight plug and play right?
Old Jan 3, 2013 | 02:47 PM
EpHatchy's Avatar
easiest to avoid jumpers is stick obd1.would probably be easier to find obd2 stuff though.
Old Jan 3, 2013 | 05:58 PM
hybridmiklo's Avatar
I dont think you understood the post ephatchy. But the answer is yes, obd1 ls dizzy will fit and run perfect. I did the same in my 90sedan with b20.
HondaRexBoi
Apr 20, 2021 11:52 PM
4dr_eg
Oct 18, 2013 01:20 AM
crxb16a90
Engine Management and Tuning
Mar 2, 2010 04:42 PM
Civic
Jun 7, 2003 08:55 AM
