code 22 (No Swap) (New Solinoid)
Old Apr 2, 2007 | 06:12 PM
fastcrx420's Avatar
Default code 22 (No Swap) (New Solinoid)
Ive got a 92 Si org motor 123k on it. Everything is plugged in and oil is full. Tried swapping the solinoid gasket and screen are new. The problem comes in a 3rd gear pull on the highway vtec crossover hits and cel comes on. Any ideas on this problem is appreciated.
Old Apr 2, 2007 | 06:26 PM
fastcrx420's Avatar
Default Re: code 22 (fastcrx420)
bump this really bothers me
Old Apr 2, 2007 | 07:54 PM
fastcrx420's Avatar
ttt
Old Apr 5, 2007 | 09:25 AM
fastcrx420's Avatar
bump
Old Apr 5, 2007 | 09:57 AM
Luserkid's Avatar
Did you check to make sure that theres no breaks in the wiring for VTEC? Make sure the connector on the solinoid is connected good and such.
Old Apr 5, 2007 | 10:33 AM
spork motorsports's Avatar
* B A N N E D *
Default Re: code 22 (Luserkid)
i was throwing the same code last night, check all your plugs, check oil level, turns out i had a small leak between the head and the solenoid, did you use hondabond when you put that solenoid on?
Old Apr 5, 2007 | 06:59 PM
fastcrx420's Avatar
Default Re: code 22 (spork motorsports)
no hondabond but new gasket/screen. have not checked plugs but would that throw off vtec? Ill check the plugs tommorow. All connections are good as i can tell man nothing looks hacked its a no swap 92 si z6
Old Apr 6, 2007 | 02:40 AM
fastcrx420's Avatar
ttt
Old Apr 8, 2007 | 06:49 PM
fastcrx420's Avatar
bump
Old Apr 10, 2007 | 10:18 PM
Bejita's Avatar
Well....The only thing I could think of is that maybe your VSS is taking a ****. I dunno....What code are you throwin'?
Old Apr 10, 2007 | 10:27 PM
guttedEF's Avatar
Does this only happen in 3rd gear? Has to be coincidental because a manual ECU doesn't know what gear you're in. Does the CEL just blink on or do you have to physically reset it?
Old Apr 15, 2007 | 06:55 AM
fastcrx420's Avatar
yea man as soon as i change to 3rd gear BAM code 22. I have to turn car off and on and code goes away. vss talking ****? i do feel that my spedo could be off at times could this throw the 22 in 3rd?
Old Apr 15, 2007 | 11:03 AM
fastcrx420's Avatar
bump
Old Apr 16, 2007 | 06:59 AM
fastcrx420's Avatar
Bump for someone to help jesus i know this isnt a one off problem
Old Apr 16, 2007 | 07:01 AM
guttedEF's Avatar
Maybe it's just the speed you're going, and not really that fact that you're in 3rd. Try skipping 3rd gear and see what happens.
Old Apr 16, 2007 | 07:22 AM
fastcrx420's Avatar
Default Re: (guttedEF)
i will try that right now good idea
Old Apr 16, 2007 | 07:59 AM
sauceja's Avatar
Default Re: (fastcrx420)
Ummm yes the ecu does know what gear you are in.
I have a chipped P28 and when datalogging it tells me exactly what gear I am in.
I had this same problem. When running a 1/4 I hit third gear and bam, CEL.
Try this because this was also a symptom
Get up to about 55 mph and make sure you are in 5th gear. Now slow down while leaving it in 5th gear. Don't push the clutch in or anything, just slow the car down in gear. Let me know if you get a CEL when you get down to around 10 or so MPH.
I didn't have a single oil leak on my motor. Had a dent in my oil pan and oil pickup tube was a little tweaked but all was decent.
Only other lead I had was that the ignitor coil in the dizzy could cause this.
I ended up selling the motor and never got around to finding the root cause. If I get the same thing on my new motor then I will swap the dizzy out for my GSR one to verify that.
Good luck and let us know if you figure it out.
Old Apr 16, 2007 | 06:19 PM
fastcrx420's Avatar
Default Re: (sauceja)
bump the night away
Old Apr 17, 2007 | 08:02 PM
fastcrx420's Avatar
i tried the 5th to about 15mph no CEL. did how ever notice at 60mph my mph needle jumped for a split second.
Old Apr 22, 2007 | 06:04 PM
fastcrx420's Avatar
bump
Old May 1, 2007 | 07:57 AM
fastcrx420's Avatar
Ok fellas I'm At my ends with this. Ive tried a new solinoid a new VSS and the fluids are full. Its a z6 no swap 92 si hatchback. I keep throwing code 22 in 3rd gear please help.
Old May 1, 2007 | 04:21 PM
fastcrx420's Avatar
bump
Old May 2, 2007 | 07:23 AM
fastcrx420's Avatar
ttt
Old May 2, 2007 | 07:46 AM
Slurp56's Avatar
Well, a Code 22 is a VTEC Pressure Switch problem, not the solenoid. You need to determine if the problem is electrical or mechanical. To check electrical, use a multimeter and check for continuity between the VTEC Pressue Switch wire (Blue with black stripe) and the ECU (Pin D6). Then use a test light or do a continuity check for the Black Wire at the VTEC Pressure Switch to Chasis ground. You need to verify it's got a good ground or you will get a CEL.
If that checks out OK, then the problem could be with the VTEC Pressure Switch itself (not super likely) or their could be debris blocking your oil supply passage. Maybe when you removed your old filter, a piece of rubber or other debris fell into the feed passage. You can remove the solenoid and visually inspect the passage on the head, solenoid housing, and the filter itself. Another option is to pickup a service manual and follow the troubleshooting guide. You can connect an oil pressure sensor to an aux port in the head and watch it when you go into VTEC. This will let you know if you've got enough oil pressure building.
Who knows, it could be something totally un-related. Could be a clogged/damaged oil pickup, clogged oil filter, weak oil pump (not likely). Something is allowing enough oil pressure to build to shut off you low oil idiot light, but not enough pressure to properly supply the engine with the pressure it needs. Being that this just happened after you changed the VTEC Solenoid filter, I'd say none of these are likely the problem.
Old May 2, 2007 | 04:33 PM
fastcrx420's Avatar
Default Re: code 22 (Slurp56)
Could be a clogged/damaged oil pickup? The guy i bought it off of did put a new oil pan on the car. how easy is it to replace one?
92HBack
Aug 30, 2009 03:32 PM
JdelMsolG
Dec 9, 2008 03:35 PM
36Chitownrunnin
Jun 17, 2008 08:44 PM
vtec8804
Oct 20, 2006 07:56 AM
SOHC_MShue
16
Apr 30, 2005 12:58 PM
