Apexi IHI Turbo Question
Old Apr 2, 2007 | 04:30 PM
sohcT's Avatar
Default Apexi IHI Turbo Question
I have an IHI AX53 turbo from the Apexi SOHC turbo kit. Last year the Apexi cast manifold that came with the kit started to develop some small cracks. I am looking to purchase a new manifold and downpipe. I was wondering if this turbo has standard IHI flange's? I understand that one of the 4 bolts on the turbine inlet side is a blind hole and I will probably only be able to use 3 of the 4 studs. Will that be sufficient and not cause an exhaust leak? Which BMC Race turbo adapter should I use to bolt to a T3 flanged manifold? Which 5 bolt downpipe flange would fit? I can post pics if needed. Thankyou in advance!
Old Apr 2, 2007 | 04:40 PM
sohcT's Avatar
Default Re: Apexi IHI Turbo Question (sohcT)
Pics
Old Apr 2, 2007 | 05:04 PM
KevronsEG's Avatar
Its a Stantard Garrett T25 flange The greddy, GT series turbos use the same one. Same for the Downpipe flange.
Kevron
Old Apr 2, 2007 | 07:05 PM
creechrr's Avatar
Default Re: Apexi IHI Turbo Question (KevronsEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevronsEG &raquo;</TD></TR><TR><TD CLASS="quote">Its a Stantard Garrett T25 flange The greddy, GT series turbos use the same one. Same for the Downpipe flange.
Kevron</TD></TR></TABLE>
Thanks for the info.
You eventually went with a GT28RS, right? How much did you put down? Dyno graph?
Old Apr 3, 2007 | 01:17 PM
KevronsEG's Avatar
Default Re: Apexi IHI Turbo Question (creechrr)
this was on 10psi with 3in DP and 2.5 midpipe and 2.25 twin loop muffler. tons of room to grow.
video here
http://video.google.com/videop...hl=en
Modified by KevronsEG at 5:30 PM 4/3/2007
Old Apr 3, 2007 | 01:45 PM
creechrr's Avatar
Thanks.
To clarify, this was on the Apex'i manifold? Any clearance issues with the block?
Old Apr 3, 2007 | 02:33 PM
KevronsEG's Avatar
yes apexi manifold. no clearance problems here are few pics.
Old Jun 18, 2007 | 09:17 AM
kit88's Avatar
What numbers was your best with the apexi turbo, I´got one and running 15 psi.
Not idea about my numbers.
Do you feel better your gt28 than the apexi??
Also where do you get this downpipe, looks sick.
Old Aug 14, 2007 | 03:14 PM
kit88's Avatar
Default Re: Apexi IHI Turbo Question (kit88)
Hey bro, I want a dp like this, please help me to get one.
jacoblytle
May 10, 2014 01:53 PM
sohcT
Jun 11, 2006 08:45 AM
Civicman86
Jan 13, 2005 07:17 AM
jcmcnugent
Welding / Fabrication
14
Jan 9, 2005 07:54 PM
Civicman86
Dec 18, 2004 09:28 AM
