ApexI and Greddy manifolds?
I recently noticed that my sohc ApexI turbo manifold developed a small crack. I have access to a Greddy manifold. Will my Apexi turbo bolt up to a Greddy manifold?
i used an apexi mani, w/ a T28(similar turbo). should be a common T2 flange! i dont know about placement of turbo though downpipe might not bolt up right, and put it at a weird height?
Re: (nelsmar)
My apexi manifold did the same thing and I bought a greddy manifold to replace it. The problem is that the studs on the IHI turbo come out of the turbo and the nuts sit above the flange on the apexi manifold, whereas on the greddy manifold the studs come out of the manifold side and the nuts sit under the flange of the turbo. You would only be able to drill out three of the stud holes on the turbo also because one of the holes would end up inside the dp elbow. I would see if you could find someone to weld the manifold and fix the crack, or find an aftermarket manifold. I ended up just getting a gt28r turbo, to mount to the greddy manifold.
carma42
07-05-2006 08:11 PM
