timing off
Old Apr 1, 2007 | 03:37 PM
93-lsvtec-eh2's Avatar
Default timing off
whats up i just did a b16 swap in a 99ex and when i finished i tried to start it and it popped back through the intake, so i pull the valve cover and check timing and the timing is dead on. so i pull the cap and the rotor is pointing toward three at tdc instead of one. so i change the plug wires to correct the firing order and it fires and runs but will barely rev up and has no power. so i was wondering how can the dizzy be 90 degrees out i searched but no one had the answer
i've checked about everything i can think of the timing being 180 out and the dizzy being 180 out. and the pug wires were on correctly on both ends
Old Apr 1, 2007 | 05:50 PM
high_revs's Avatar
firing order is wrong......1-3-4-2 is how it should be
Old Apr 1, 2007 | 06:14 PM
outtacontrolsol's Avatar
Default Re: (h2b_eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">firing order is wrong......1-3-4-2 is how it should be </TD></TR></TABLE>
while your at it make sure that your injector harness is installed properly. Just a little extra assurance...
Old Apr 1, 2007 | 06:15 PM
high_revs's Avatar
Old Apr 2, 2007 | 05:46 AM
i know but i was wondering how you can change it in the dizzy if you can i just changed to plug wires where the rotor was poinring to get it to run but i want it to point at one a tdc not three how can i fix that
Old Apr 2, 2007 | 07:05 AM
high_revs's Avatar
either your cam is positioned wrong meaning timing belt is not on right, or your dist. is not mounted right.
Old Apr 2, 2007 | 07:23 AM
91' LS-VTEC's Avatar
never heard of the cam being potioned wrong, but I guess that would make since to the timing being off
Old Apr 2, 2007 | 08:57 AM
the timing is right both cam gears line up when the crank is at tdc i've did everything short of pulling the crank puller and looking at the timing mark on the oil pump
and the dizzy is mounted right the flat part of the cap is up
Old Apr 2, 2007 | 02:48 PM
MightyMouseTech's Avatar
Default Re: (93-lsvtec-eh2)
You can not install the dizzy wrong. It will only fit on one way, unless you used a bigger hammer.
wideload
10
May 28, 2010 10:26 PM
mwwtx
Feb 10, 2010 04:26 PM
downeyballz
Jun 11, 2007 06:38 PM
5thgencivicr
Jun 25, 2005 10:58 PM
White86CRXSi
Aug 27, 2004 03:19 PM
