94 civic - clutch(exedy) problem
Old Apr 1, 2007 | 03:01 PM
Corradonrg's Avatar
Default 94 civic - clutch(exedy) problem
Just recently, whether i am in gear or in neutral, when i press the clutch pedal in, all the way at the end it grinds or feels like the springs are too tight and grind(creates hagard feeling resistance at end of pedal). Just for the last maybe half inch or inch of clutch to the end.
The car does drive fine and shifts fine, just wondering if this is the start of a problem. =P
If I pump the clutch a few times the grind or spring snap feel goes away from it, but comes back.
Just drove across the country, any ideas if i just need to lube something up?
Its an exedy clutch, i think its the normal oe replacement kit
Clutch fluid is full
Old Apr 1, 2007 | 05:04 PM
Archidictus's Avatar
Unceasing Measure
Default Re: 94 civic - clutch(exedy) problem (Corradonrg)
Blown clutch master cylinder. Replace the slave cylinder while you're at it.
Old Apr 2, 2007 | 12:28 PM
Corradonrg's Avatar
Default Re: 94 civic - clutch(exedy) problem (Archidictus)
the master cylinder was a problem before, leaked out all the fluid but that problem went away, it does leak a lil bit.
thanks for the help
bigdem1civic
Transmission & Drivetrain
Mar 13, 2014 05:50 PM
TypeR324
Honda S2000
Sep 29, 2009 10:05 AM
phatsindabuildin
Mar 25, 2008 06:57 PM
xhatchracerx
Aug 31, 2007 01:22 PM
User 5426
Aug 1, 2003 06:36 AM
