fuel pressure poblems HELP!!
Old Apr 1, 2007 | 11:30 AM
Fresh_Si's Avatar
Default fuel pressure poblems HELP!!
Ok well i have a 00 Civic Si B16 with a Jackson supercharger on it. I need to get through DMV to get my car tagged but my check engine light keeps commin on for (Fuel Bank 1 to rich) I checked my fuel pressure with my gauge n it says 36 with hose on n 41 w/o the hose. Im just lookin 4 some advice i have 310 injectors, fuel pump, fuel rail, n regulator. Please help me. TY
Old Apr 1, 2007 | 05:48 PM
civicstar's Avatar
Default Re: fuel pressure poblems HELP!! (Fresh_Si)
can it possibly be O2 sensors?
Old Apr 1, 2007 | 06:49 PM
Fresh_Si's Avatar
Default Re: fuel pressure poblems HELP!! (civicstar)
do u think it could b the O2?? it just keeps throwing the same code (To rich)
Old Apr 1, 2007 | 07:03 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fresh_Si &raquo;</TD></TR><TR><TD CLASS="quote"> i have 310 injectors, fuel pump, fuel rail, n regulator. Please help me. TY</TD></TR></TABLE>
what kind of fuel managment system do you have to control those injectors?
Old Apr 1, 2007 | 07:04 PM
civicstar's Avatar
when i threw a code 41, it was my primary o2 sensor
Old Apr 1, 2007 | 07:07 PM
Fresh_Si's Avatar
Default Re: fuel pressure poblems HELP!! (non-VTEC)
just the rgulator n gauge ATM. Im not sure wht to get to rly control them, cause if i get a obd1 ecu my friend has crome but then i dont think i can pass inspection with the obd1. Any suggestion?
Old Apr 1, 2007 | 07:09 PM
Fresh_Si's Avatar
Im throwing a p072 i think its a "p" code DTC code
Old Apr 1, 2007 | 07:12 PM
non-VTEC's Avatar
your running to rich because the ECU is calibrated to run stock 240cc injectors. just putting an adjustible fuel pressure regulator will not give you enough adjustment (if any at all) to compensate for the extra injector flow.
you need to have it properly tuned. period. there is no fix anyone can do for you unless you pay someone to tune your ecu.
good luck.
Old Apr 1, 2007 | 07:15 PM
Fresh_Si's Avatar
how can u tune a obd2 ecu?
Old Apr 2, 2007 | 03:14 AM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fresh_Si &raquo;</TD></TR><TR><TD CLASS="quote">how can u tune a obd2 ecu?</TD></TR></TABLE>
you can't.........you need to convert to OBD1 then run hondata, crome, neptune, uberdata or any other OBD1 tuning software.
Old Apr 2, 2007 | 07:05 PM
Fresh_Si's Avatar
Iv ordered stock injectors so i hope that fixes it. As 4 the obd1 i will do that soon as i get it through the DMV cause i know someone that has Crome n he can set it up 4 me. But thx alot 4 ur time.
NickMorneau
May 30, 2013 05:15 PM
nv707
Oct 7, 2007 06:11 PM
existanzcivicb20
Apr 20, 2006 09:23 PM
onefstek
Dec 5, 2005 10:29 PM
Litoman
Aug 15, 2002 07:53 PM
