Using a torque wrench
Old Mar 30, 2007 | 09:32 PM
NuRon's Avatar
Default Using a torque wrench
When do I start using it? You guys know how there's sort of a freeplay first, where you can turn things with your fingers? Do I start when I can't tighten it with my hand any more or what? Sorry for the simpe question but all I've been doing is tightening by feel--no stripped threads yet *crosses fingers*. Not for critical parts though, just door bolts and stuff like that. Thanks
Old Mar 31, 2007 | 01:53 AM
SlowReaction's Avatar
Default Re: Using a torque wrench (NuRon)
I'm not exactly sure what your trying to ask but i'll try to help you out. Obviously the job the torque wrench its to tighten bolts,nuts, etc down with to a certain spec. If your going to torque something down your not going to try to tightenin it by feel as much as you can. Just turn the bolt/nut until its snug then, set the torque wrench and turn the bolt with the wrench until you get the click.
Old Mar 31, 2007 | 06:55 AM
PrettyLude's Avatar
it shouldn't matter if the bolt or nut is loose or finger tight, once you start using the torque wrench it take care of it.
Old Mar 31, 2007 | 07:37 AM
02 accord's Avatar
Do hand tight first, then use the torque wrench. Makes the job go a lot faster.
Old Mar 31, 2007 | 12:40 PM
Pauly321's Avatar
All the torque wrench does is click when you reach the specified foot pounds. You can tighten it up all you want by hand, then use the torque wrench to tighten it to what you need.
Old Mar 31, 2007 | 12:53 PM
NuRon's Avatar
Ahh I get it, thank you very much guys!
Old Mar 31, 2007 | 04:45 PM
Top Ramen's Avatar
Default Re: (NuRon)
Also, when you use the torque wrench, turn it smoothly and evenly until it clicks. If you stop and go or slow way down as you get near the point where it breaks loose, it is not as accurate.
Good luck with your project.
Old Mar 31, 2007 | 06:27 PM
Chiovnidca's Avatar
Default Re: (Top Ramen)
If you're using a beam type torque wrench dont tighten until it clicks.
Old Mar 31, 2007 | 08:39 PM
Top Ramen's Avatar
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">If you're using a beam type torque wrench dont tighten until it clicks. </TD></TR></TABLE>
That would be more of a "snap" sound. . .
Old Mar 31, 2007 | 09:41 PM
Default Re: (solbrothers)
Also after your done using it reset it back to 0.
ninjaturtleEG
Nov 23, 2011 03:18 PM
ray.riddler92
Jul 27, 2011 05:07 PM
GSaura
Nov 30, 2006 07:16 PM
Smith Wise
Apr 15, 2003 04:02 PM
jonsteR
Aug 10, 2001 08:55 AM
