Spark Plugs and Wires
Old Mar 30, 2007 | 04:43 PM
honda94accord's Avatar
Default Spark Plugs and Wires
Im sure this has been posted millions of times on here. But im just wondering what the best spark plug and wire combo would be for a 94 accord ex with an F22B1?
Old Mar 30, 2007 | 05:00 PM
JDM_DC4_Fanatic's Avatar
Default Re: Spark Plugs and Wires (honda94accord)
NGK Plugs and wires for stock/mild mods
Old Apr 7, 2007 | 06:03 PM
Conflicted's Avatar
I dont want to start a new topic.
NGK plugs I have been told before are the best. Is it best to get the plug that is most closest to stock, or is it smart to go with platinum or iridium? I have the stock F22b2 motor in my 94 lx coupe and I havent changed the plugs and the time is coming, any information would be excellent.
The 2nd question I have is, right now I have nology hot wires and i'm hearing mixed information about the kind of wires to be using. Should I use the stock set and its adequate? OR, should I use an aftermarket set?
Any information is appreciated, thankyou very much in advance.
Old Apr 7, 2007 | 07:30 PM
steerh67's Avatar
Default Re: (Mani Fresh)
I honestly prefer stock wires simply because of the fact that they last about 4x longer than most aftermarkets.
Old Apr 10, 2007 | 08:19 AM
Conflicted's Avatar
What kind of plugs are people using?
Old Apr 10, 2007 | 08:33 AM
Bruce Banner's Avatar
NGK RRRRRRRRRRRRRRRRrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Old Apr 10, 2007 | 10:10 AM
Conflicted's Avatar
Are those similar to stock or are these the iridium types?
Old Apr 10, 2007 | 01:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mani Fresh &raquo;</TD></TR><TR><TD CLASS="quote">Are those similar to stock or are these the iridium types?</TD></TR></TABLE>
it is OEM
Old Apr 10, 2007 | 02:27 PM
Conflicted's Avatar
Is it better to go with Iridium?
Old Apr 10, 2007 | 02:53 PM
someone else's Avatar
It Wasn't Me!
Unless you get in to making crazy power OEM plugs and wires will do you fine. I work at a dealer and regularly see drivability problems caused by aftermarket wires.
Plus as stated above the factory wires outlast the aftermarket stuff by a long time usually.
Old Apr 10, 2007 | 03:11 PM
Conflicted's Avatar
Im really never gonna go crazy with the car, it at its peak will see an H22 motor swap and maybe thats it. My other car has a turbo and is pushing 300hp, that gives me enough problems already.
Old Apr 10, 2007 | 03:26 PM
The myth says yes.
but I was rather swap out new coppers more often
Old Apr 10, 2007 | 04:01 PM
It Wasn't Me!
Default Re: (Bruce Banner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bruce Banner &raquo;</TD></TR><TR><TD CLASS="quote">The myth says yes.
but I was rather swap out new coppers more often</TD></TR></TABLE>
If by myth you're referring to how long plug wires last it's not a myth. I have a tech that checks resistance on wires all the time. They last 90-120k easy in this climate as long as the plugs are changed regularly.
Conflicted's Avatar
Interesting point, stick with stock, just switch them out every so often. I remember back in the day I had Bosch4 Platinums, and they were so heralded, and then suddenly everyone said, screw it, go with stock.
Old Apr 10, 2007 | 04:22 PM
hometheaterman's Avatar
I've heard to go with OEM plugs and wires but I went with a set of Taylor Thundervolt wires as I had a gift card thingy or discount whatever you want to call it for Summit racing so I got them instead. I got those with OEM NGK plugs from the dealer and it seemed to really help after doing the tune up. I also went with a Napa cap and rotor. So far this setup is good but I don't know how long the wires will last. I've heard a lot of aftermarket wires don't last as long. I haven't had mine on even a year yet but so far they are good. I've probably had mine 8 months or so.
Old Apr 10, 2007 | 07:27 PM
Conflicted's Avatar
****, i've had my nology hotwires on my car for at least 6 years now. Maybe its time to replace those too!
AllMotor12s
May 19, 2004 02:30 PM
jdmjeff
12
Nov 20, 2003 01:26 AM
Eibach95Civic
41
Aug 31, 2003 01:42 PM
SilverIntegra
Apr 2, 2002 08:32 AM
crookedletterd
Jul 29, 2001 08:40 PM
