Am i burning oil?
Old Mar 30, 2007 | 03:26 PM
sirhavok's Avatar
Default Am i burning oil?
hhhmm i dont think im burning oil. but the oil has went down. in about a month the oil went down to a little over half way.
I am throwing codes 6 , 10, 22
I have JDM b16a first gen with stock header and ITR intake manifold
in a 89 civic hatchback si
am i burning oil??
This is the dip stick
F__
_
_
_ -------- this is where my oil went down to in a month.
_
_
E__
i did have a bad dizzy for about a week, untill i found out that it was bad, then i replaced it.
Thx for any help.
Modified by sirhavok at 5:36 PM 3/30/2007
Old Mar 30, 2007 | 03:48 PM
mra4886's Avatar
Default Re: Am i burning oil? (sirhavok)
ive heard that the b16 are common to burnin oil. or maybe you have a oil leak.
Old Mar 30, 2007 | 04:36 PM
sirhavok's Avatar
yea thats what i was trying to find out.. if this was common or not. im not leaking oil so i dont think thats it.
Old Mar 30, 2007 | 04:40 PM
91ed9's Avatar
Default Re: (sirhavok)
how often do you hit Vtec?
vtec burns oil as well as gas milage
so if you rev out your engine thats normal over a months period of time
Old Mar 30, 2007 | 04:42 PM
sirhavok's Avatar
well actually im throwing code 22. which means my vtec cylinoid thingy is broken. or the censor is bad.
so i dont even hit vtec.. i do kinda ride the motor hard.
nothing to crazy.
Old Mar 30, 2007 | 04:43 PM
civhatch90's Avatar
are you beating the **** out of it everyday?
smoke? leaks?
Old Mar 30, 2007 | 04:44 PM
sirhavok's Avatar
no smoke. no leaks. i never see any oil on the floor at all. ever.
Old Mar 30, 2007 | 04:45 PM
sirhavok's Avatar
i do have a really really bad wiring job on this bitch.
can that be it?
Old Mar 30, 2007 | 05:00 PM
sbarmann's Avatar
How does "vtec burn oil"? I would be really interested to know.
Old Mar 30, 2007 | 05:02 PM
sirhavok's Avatar
vtec opens the valves to use more oil, and by hitting vtec, your using and burning more oil.
higher rpms
Old Mar 30, 2007 | 05:09 PM
tougetuned_ef's Avatar
if theres no oil under your car then your burning it. take a white rag and wipe above your exhaust tip see how black it gets
Old Mar 30, 2007 | 05:12 PM
sirhavok's Avatar
hhmm common reasons why i would be burning oil?
Old Mar 30, 2007 | 06:21 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhavok &raquo;</TD></TR><TR><TD CLASS="quote">vtec opens the valves to use more oil, and by hitting vtec, your using and burning more oil.
higher rpms</TD></TR></TABLE>
This statement is so full of **** I almost want to put it in my sig. You don't know what the f uck you are talking about.
If an engine is burning oil, it is due to worn parts. The ONLY production car that is designed to use oil is any car with a rotary engine.
The most common reasons to use oil are worn valve guides and seals or piston rings if it doesn't leak.
Vtec burns oil.....Thats the funniest **** I think I have heard all ******* day in this forum.
Old Mar 30, 2007 | 09:06 PM
Tippyman's Avatar
This thread is just chock full of mis-information.
Old Mar 30, 2007 | 09:21 PM
ALLMOTORCRX20's Avatar
code 22: vtec pressure switch
Try checking the black wire and make sure you have a good ground.
Use a multimeter to verify this.
Old Mar 30, 2007 | 09:36 PM
Vitamin_b16's Avatar
if you drive it hard its normal to use oil, the rings can only hold so much pressure....its called blow by
Old Mar 30, 2007 | 10:54 PM
Lamchop0000's Avatar
please dont spread aids...
highwhey
Nov 11, 2010 05:53 AM
19integra94
Dec 26, 2008 01:51 PM
Inextricabledrvr
May 3, 2008 09:42 AM
wm5holla
10
Mar 24, 2003 11:00 AM
PY2KITR1060
May 4, 2002 01:30 PM
