any in take pump good for 600-700 hp?
been searching i was gona run the bosch pump that endyne has that was mofided to fit in the stock tank but iv read it was discounted.. are there any other intake pumps besides the 255?
I would have to say when reaching that amount of WHP it would be wise of you to upgrade your fuel system to an external pump. I have seen the 255 reach 550+ but I can recommend you using it for 600-700WHP. Why not just change to an external pump?
Yeah go with a external pump. But there is a way to run an internal that will handle that. You can run two 255's intank. You just have to fab a bracket & then you run two feed lines to a y connecter then to the rail. Alot of people do this. It works but think about this: two 255 pumps $200, Two -8 to -10an lines $90ish, -an y fitting $20ish, plus the fabbing. An aeromotive a1000 is like $350 +/-. Very close to possibly cheaper & no fabbing. Will handle 1000hp.
i was trying to stay away from getting a sump.... if i were to put a sump i just weld it up there? is there a specife place on the tank it has to go?
I've seen people get away w/o a sump tank. But I would recommend one. Go with an aeromotive a1000. Its **** man. Thats the way I went. what hp are you puttin down now.
none right im still building the car...... how reliable is the a1000 i was reading that they can brun up if u run them on the street... not that im going to dd this car by any meens but an occasionally drive on the street would be nice...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97gsrcoupe »</TD></TR><TR><TD CLASS="quote">none right im still building the car...... how reliable is the a1000 i was reading that they can brun up if u run them on the street... not that im going to dd this car by any meens but an occasionally drive on the street would be nice...</TD></TR></TABLE>They can over heat and burn up if you drive them alot. A car that I tune has one and is driven pretty often with out any issues.
You can make 600hp on a 255 pump..... Anything over that is pushing it.
well iv heard of people useing voltage regulators to help pump life.... it would be dirvn mabey once a week up to my work so i could clean it....
I am running on my Talon the A1000 inline fuel pump with a bosch intank inside my fuel cell. Just keep your walbro 255 and add the A1000 inline pump. If you cant afford to run the stainless steel lines at this point you can pick up ruber nitrate line for a pretty good price and it holds up to 300psi.
600-620whp seems to be about as high as one should go for the stock pump location. there's a few easy ways to sump your tank without spending a fortune. Just search around. Stan @ fast-turbo.com showed me a really easy way. I'm just gonna build my own sump. Why risk your motor over a couple hundred dollars, at most. Just take the extra time and do it the right way. I'm running a Single bosch external pump with -10an SS feed line kit from Fast-turbo.
-Chad-
-Chad-
CarbonEG43
Engine Management and Tuning
Feb 2, 2013 06:45 AM
