idle from 1000 to 1500???
Old Mar 30, 2007 | 10:37 AM
DC2_8.2K's Avatar
Default idle from 1000 to 1500???
question....my car, the previous owner installed a new disturbertor and the car idles weird... it'll jump from 1000 to 1500rpm back and forth. when i'm driving, its ok, but when i put it in neutral, it starts to idle it that again. is it because they didnt install the disturbertor correctly? another thing is that yesterday i was shifthing around 4-5,000 instead of 2500 all day and then it stopped idling weird. the car idle normally again, just sitting at 900-1000. does any have this problem also? let me know. thanks!
Old Mar 30, 2007 | 11:02 PM
computerfreak's Avatar
Default Re: idle from 1000 to 1500??? (EJ1_spoolin)
check your vaccum lines to the intake mani, if thats punctured or something that could cause a high idle
also if theres a CEL, run teh numbers that could tell you why its idling high
Old Mar 30, 2007 | 11:49 PM
esoterEK..'s Avatar
Need to know too . my idle bounce from 1000 to 1500 also.
Old Mar 31, 2007 | 10:58 AM
DC2_8.2K's Avatar
Default Re: idle from 1000 to 1500??? (esoterEK..)
thanks for the reply...
yesterday my friend looked at it...and he unplugged this wire behind the intake manifold, and it stopped idling weird...but then the check engine light is on because that wire is unplugged. he says its fine....said something that when stuff gets in it, it clogs it up so thats why it idles like that.... is this common for civics?
Old Mar 31, 2007 | 06:57 PM
arc_55's Avatar
the wax pellet on the fast idle thermo valve sometimes becomes lazy and doesn't close all the way causing the idle air control motor to flucuate idle speed. After a good hard rip the car will tend to idle normally, but the problem will only rise again once cold.
easycheese
Jan 14, 2008 10:04 AM
TurboSI24
Nov 23, 2005 03:39 PM
Tony92lude
Mar 1, 2004 06:38 AM
Civic Racer X 7
Jul 23, 2003 07:19 AM
