AEBS T-Sleeves can they handle a .5 overbore??????????
Old Mar 30, 2007 | 06:33 AM
spoolingb20's Avatar
Default AEBS T-Sleeves can they handle a .5 overbore??????????
Well I am now in the process of rebuilding my hatch again and I need to have my sleeves rebored. I currently have in there AEBS T-sleeves in an 84mm bore. This is in a 1.8 GSR block bored to a 2.0. The vlave reliefs on my CP pistons took a **** on me and destroyed my turbo. What also happened was because there were pieces of the piston missing from the tops it was no longer balanced and there was a ton of piston slap expecially in cyld. 2 and 3. This has made it so that pistons rings will no longer seat properly in the 84 mm bore giving me way low compression (140 accross)
So my question that I have lead up to is am I able to safly take my cylinder bore to 84.5 with the sleeves that I have?
Second question is I am in a toss up between running Arias and CP pistons is there anything I can be made aware of w/ the 84.5 models is one better than the other?
Thanks
Steve
Old Mar 30, 2007 | 06:49 AM
nonvtecallmotor's Avatar
Default Re: AEBS T-Sleeves can they handle a .5 overbore?????????? (spoolingb20)
I have my AEBS sleeves bored to 85mm and I'm turboed also. I have Wiseco pistons in my set up.
Old Mar 30, 2007 | 07:01 AM
So there is nothing to take into compensation when reboring after market sleeves..
Old Mar 30, 2007 | 08:11 AM
99B16Si's Avatar
84.5mm bore is very common and should not be a problem at all
Old Mar 30, 2007 | 03:21 PM
DVC2008's Avatar
Default Re: (99B16Si)
You can bore it. NO problem
Old Mar 30, 2007 | 06:18 PM
vaporboy12's Avatar
Default Re: (DVC2006)
yes sir i took my 84mm aebs sleeves to 84.5mm
Old Mar 30, 2007 | 08:19 PM
blackeg's Avatar
Default Re: (vaporboy12)
i think u can go as high as 86mm if you did not o-ring.....
no problems at all going 84.5mm, thats where ill be when i blow my current setup eventually, maybe even 85mm
5_Lug_B
Aug 5, 2007 09:26 PM
JDMotive
May 28, 2004 02:26 PM
VanHonda
Apr 8, 2004 07:36 PM
ITRbroham
Feb 18, 2003 06:11 AM
Benny Z
Dec 20, 2002 03:35 AM
