18g turbo oil leak
i have a 18g turbo and it leaks real bad oil in the piping. Is it bad seals? do you think by adding a restrictor will cure the problem?.....i've searched for info about the turbo, but found every little. any advice would be helpful.
If your return line isn't kinked, I guess a restrictor will be a Band-Aid to help you get more mileage out of it. Are you using the oil feed line that came with the kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whteteg8901 »</TD></TR><TR><TD CLASS="quote">had the same problem for a bit i just took it apart and put teflon tape and retightened the oil feed line on the turbo. no more leaks... 3 weeks so far</TD></TR></TABLE>
You misunderstood him. The oil feed isn't leaking, he's getting oil inside the piping.
CivicDude2k4
Sep 5, 2006 08:24 PM
Elite Hatch
Oct 20, 2002 05:43 AM
