All motor ?
Old Mar 29, 2007 | 07:51 PM
egsr6's Avatar
Default best OEM All motor ?
i was tryin to get the highest"SAFE" compression & the most possible HP outta OEM parts, I was wonderin how a b18a block W/b20 crank Gsr rods,B16 pistons,mildly shaved head,Ctr cams w/ITR IM,...or itbs,..anyone running this,..or now any other combinations to get a mean OEM b series
Old Mar 29, 2007 | 08:05 PM
Grand's Avatar
Default Re: best OEM All motor ? (egsr6)
gsr rods with an 89mm crankshaft are going to creat just a little bit of a problem
Also why would you replace your crank for the same crank ? b18a/b/b20b/z all share the same 89mm stroke crankshaft and all use the same connecting rods which are very siginificantly shorter than gsr rods.
The crank/rod combo you have listed suggest's your in a little over your head when it comes to building an engine. Besides that the setup would be a decent oem parts build
Old Mar 29, 2007 | 08:11 PM
egsr6's Avatar
thats why i posted bro,..wanting to know "tried & true" ua know,..but should it be a decent motor
Old Mar 29, 2007 | 10:21 PM
96Spec Ek's Avatar
Default Re: (egsr6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsr6 &raquo;</TD></TR><TR><TD CLASS="quote">thats why i posted bro,..wanting to know "tried & true" ua know,..but should it be a decent motor</TD></TR></TABLE>
No, did you even read what he said? gsr rods+ls/b20 crank= wont work
Do yourself and everyone here a favor and just follow one of the thousand build threads on this site
Old Apr 2, 2007 | 05:38 PM
Dev15Bizz's Avatar
first of all b18A blocks suck, trust me and get a B18B!!! put PR3 B16 pistons in it, B16 head with Type R cams.... those pistons in the block and a b16 head will put you at about 12:1 compression, very safe and reliable build
Old Apr 2, 2007 | 07:07 PM
Grand's Avatar
Default Re: best OEM All motor ? (Dev15Bizz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dev15Bizz &raquo;</TD></TR><TR><TD CLASS="quote">first of all b18A blocks suck, trust me and get a B18B!!! put PR3 B16 pistons in it, B16 head with Type R cams.... those pistons in the block and a b16 head will put you at about 12:1 compression, very safe and reliable build</TD></TR></TABLE>
LOL.
What are the differences in an b18b block vs b18a.
Oh yeah, if they are both obd1 blocks it's just the letter
Please don't post redicolus information that you have no idea what you are talking about.
Old Apr 2, 2007 | 07:25 PM
Sam92Teg's Avatar
Default Re: best OEM All motor ? (LG_R32)
Listen to what LG_R32 has posted, and E-kick Dev15Bizz in the ***** for spreading ignorant misinformation.
Old Apr 3, 2007 | 04:42 PM
Dev15Bizz's Avatar
Default Re: best OEM All motor ? (Sam92Teg)
my bad ur right
Old Apr 3, 2007 | 06:25 PM
MoonScryer's Avatar
Little change to your list: B18a/b block/crank/rods, b16a pistons/head CTR cams. ARP rod bolts PROPERLY put in, and you can see 180'ish horsepower on a good tune. Yes, probably more if set up well.
Old Apr 3, 2007 | 08:42 PM
leeminho86's Avatar
Default Re: best OEM All motor ? (MoonScryer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MoonScryer &raquo;</TD></TR><TR><TD CLASS="quote">Little change to your list: B18a/b block/crank/rods, b16a pistons/head CTR cams. ARP rod bolts PROPERLY put in, and you can see 180'ish horsepower on a good tune. Yes, probably more if set up well.</TD></TR></TABLE>
Is he keeping the ls head or swapping it with a vtec head? I wasn't aware you could put ctr cams in an ls head
Old Apr 4, 2007 | 06:20 AM
MoonScryer's Avatar
Default Re: best OEM All motor ? (leeminho86)
^^^^ I put "b16a pistons/head CTR cams."
Old Apr 4, 2007 | 11:42 AM
leeminho86's Avatar
Oh cool, make any noticable power?
VTC#2
May 23, 2013 02:28 PM
Strange World
Dec 26, 2012 12:29 AM
FEDONV8
Dec 6, 2011 03:24 PM
twistedimage
Dec 7, 2008 04:44 PM
95civhb
Jan 29, 2008 07:49 PM
