transmission issues.
Old Mar 29, 2007 | 05:14 PM
pane93civhb's Avatar
Default transmission issues.
Hey everyone I have a b20civic eg hatch here at the shop. It is running a weird supercharger something that looks likes its from a pontiac. Anyways its using a cable trans with the cable to hydro conversion kit. For some reason i cant shift it into any gear when the car is on and the clucth is engaged. Im kinda stumped at the moment. Seems like it wont disengage for some reason. It is a brand new competition clutch stock flywheel. I pulled the trans a 2nd time just to make sure everything looked ok and it did. Does anyone have any ideas what could be going on?
Old Mar 30, 2007 | 06:43 AM
anyone no suggestions at all?
Old Mar 30, 2007 | 03:06 PM
base-op.1320's Avatar
Default Re: (pane93civhb)
Another guy just had a thread where the clutch disc was larger diameter than pressure plate and wouldn't disengage - it is in the tech/misc section
Old Mar 30, 2007 | 03:09 PM
SlowReaction's Avatar
Default Re: (base-op.1320)
does it shift into gear when the car is off?
Old Mar 31, 2007 | 09:46 AM
It does shift into gear when the car is off. For the life of me im sure the clutch is right.
Old Mar 31, 2007 | 04:39 PM
The clutch isnt right. That our there could be something wrong with the hydro system i.e. air, not enough fluid,etc. It somewhere in the clutch.
I had to remove a tranny from the car 3 time before i could figure out the problem was. Make sure the pressure plate is on correctly. Is only bolts down one way and you have to line the holes in the pp with the prongs on the flywheels together. Make sure there is no gap between the pp and the flywheels.
MastaFlyMason
Transmission & Drivetrain
Sep 23, 2017 03:58 PM
JScott3d
11
May 23, 2009 01:26 PM
blackeg
Jan 2, 2009 07:17 PM
trianglegreg
Nov 12, 2005 10:58 AM
yorace2win
Apr 4, 2002 08:47 PM
