ECU Question Turbo -> JRSC
Ive got a turbo setup now that ive decided not to install because my friends giving me a great deal on a jrsc.
That means ill be selling most of the turbo stuff, but ill be keeping engine management things.
So ill have the jrsc with:
RC 440s and 255lph fuel pump
PLX Wideband (necessary?)
Boost and Oil Pressure Guages (is oil pressure necessary?)
Kenji Chipped ECU
My question is....aside from the necessity of the wideband and oil guage...can I use the ecu?
It has a basemap for a t3/to4E @ 7psi....will it be able to work with the supercharger or should i just get a different ecu?
Kenji Chipped ECU
supercharger < turbo
He must have given you a good deal to downgrade like that....also, to answer your question...NO, they're not interchangeable, but it might still run well enough to get to the dyno
What kinda vehicle/engine are you looking to run a JRSC with. unless it is a DOHC VTEC engine, you will be very limited on what power level you can make. I own a JRSC setup so I know. LOL
