Clutch Stages and Drivability VS Performance
Old Mar 27, 2007 | 07:49 PM
lordlobo44's Avatar
Default Clutch Stages and Drivability VS Performance
Its time for a new clutch and i currently have the ACT Street Disc with a Comptech Aluminum fly wheel. I was thinking to going to a ACT 4 or 6 pad disc. I have been told that a 4 or 6 pad will have firm engagement because there are no springs on it like the Street Disc. Some people say that 4 or 6 disc's are not drivable as a daily drivers. I have also been told that they make noise. Does anyone have a 4 or 6 pad that can tell me the differences.
My Car
97 integra ls non vtech
DC sport headers
AEM Intake
2 1/4 exhaust
Old Mar 27, 2007 | 08:29 PM
drumking15's Avatar
i used to run a 4 puck unsprung...its literally a light switch....on or off...if you wanted to move slowly you have to rev higher and slip it....kinda hard to do but you get the hang of it...
a 4 puck sprung could be dd...i mean i was a delivery driver w/ what i had...its all comfort level...btw chics hated my car because of the rough ride ;-)
Old Mar 27, 2007 | 09:06 PM
lordlobo44's Avatar
Default Re: (drumking15)
what are you using now?
Old Mar 27, 2007 | 11:35 PM
drumking15's Avatar
nothing...overboosted...toasted my motor....so back to a stocker for me :-/
but started w/ a kevlar disk w/ stronger pp > went to 4puck unsprung > was about to go to a 4 puck sprung disc this season...but blew her up so time to move onto a bike
Old Mar 28, 2007 | 03:21 PM
allnaturalb16's Avatar
i am running a 6 puck kevlar sprung hub and have no problems driving around in my crx. Its a clutchnet btw
when you want it to grab it will never fail
Old Mar 28, 2007 | 11:53 PM
backwoodsman's Avatar
Default Re: Clutch Stages and Drivability VS Performance (lordlobo44)
From what I've heard the light-weight aluminum flywheels with the pressed gear rings can explode under certain conditions due to the two different expansion coefficients. So if you have the two-piece pressed flywheel I'd get rid of it and opt for a 1-piece chromoly flywheel with milled teeth.
About the clutch... Check this out...
http://www.kingmotorsports.com...at=30
Look at the clutch hard-line eliminator. Supposedly it relieves some of the clutch pressure at the pedal but not on the actual clutch. Never tried it. Worth a gander for 75 bucks. I wanted to get one for my ****.
Old Mar 29, 2007 | 12:23 PM
FarinaMotorsports's Avatar
Default Re: Clutch Stages and Drivability VS Performance (backwoodsman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backwoodsman &raquo;</TD></TR><TR><TD CLASS="quote">From what I've heard the light-weight aluminum flywheels with the pressed gear rings can explode under certain conditions due to the two different expansion coefficients. So if you have the two-piece pressed flywheel I'd get rid of it and opt for a 1-piece chromoly flywheel with milled teeth.
.....</TD></TR></TABLE>
LOL, Comptech is a good company with quality products so I don't think his flywheel will be exploding any time soon.
As far as clutches, with your mods a 4 or 6 puck disc, sprung or un-sprung, is serious overkill (our stage 2 for B series will hold around 350whp). I would stick with a sprung hub disc with either organic or kevlar linings.
b18sihatch
Mar 12, 2006 06:44 PM
W O T
Jan 24, 2005 01:32 PM
ramz7887
Mar 5, 2004 01:33 AM
91civ
13
Jul 14, 2002 08:44 AM
shamoo
Oct 5, 2001 09:22 PM
