why does my tranny keep going in the wrong gear?
Old Mar 27, 2007 | 12:27 PM
blinx9900's Avatar
Default why does my tranny keep going in the wrong gear?
ok, i have a b16b motor and trans and during the 2nd to 3rd gear shift it usually grinds at higher rpm (typical honda) but recently it started going into fifth instead of 3rd (still grinds), this happend about five times in a row! then today, i go again, im at 8000rpm i go from 2nd to 3rd and it ends up in 1st!! wtf!! thank god nothing broke, but what could be causing this?
this is my fourth civic so please no flaming saying i dont know how to shift.
here is the set up and any related parts:
96 civic
STOCK ITR gold shift-linkage
STOCK GSR shifter
weighted skunk2 shift ****
energy suspension shifter bushings.
8 lb flywheel
6 puck sprung clutch
N1 pulley
any opinions or experience would be appreacieated, im going to download the data from my ems to see how high the engine revved and post it tonight.
Old Mar 27, 2007 | 12:33 PM
soulpwr's Avatar
Default Re: why does my tranny keep going in the wrong gear? (blinx9900)
If you cant find it..Grind it!
Old Mar 27, 2007 | 12:41 PM
mgags7's Avatar
I would check the shifter and linkage and all to make sure nothing is loose or bent.
Try slowing down your shifts
Old Mar 27, 2007 | 01:08 PM
blinx9900's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">I would check the shifter and linkage and all to make sure nothing is loose or bent.
Try slowing down your shifts </TD></TR></TABLE>
i was just under there and everything was when i slow the shifts it grinds longer and harder but ill stil try it, grinding third slowly is better than ending up in first.
Old Mar 27, 2007 | 01:14 PM
mgags7's Avatar
ehh then I would think you've got a bent shift fork
Old Mar 27, 2007 | 01:23 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">ehh then I would think you've got a bent shift fork</TD></TR></TABLE>
what would cause this? dont the type r trannys have a stronger 1 piece shift fork?
Old Mar 27, 2007 | 10:02 PM
blinx9900's Avatar
Default Re: (blinx9900)
update: i was unable to find out the max rpm as my datalog was set to log short, also now my tranny wines a little at 10% throttle and my valves click... im thinking just adjust valves, change trans fluid, check compression and go from there, any ideas? i dogged it to see if i still had power and the thing still moves so i dont think i bent/broke anything :hopes:
Old Mar 28, 2007 | 06:04 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote"> what would cause this? dont the type r trannys have a stronger 1 piece shift fork?</TD></TR></TABLE>
well for one, jamming your car into gear while the syncro is still grinding and not yet engaged would be one way to bend a shift fork. A very easy way actually.
Old Mar 28, 2007 | 08:43 AM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">well for one, jamming your car into gear while the syncro is still grinding and not yet engaged would be one way to bend a shift fork. A very easy way actually.</TD></TR></TABLE>
makes sense, but what are you supposed to do when your tranny grinds, just shift slow and let grind as long as it takes?
Old Mar 28, 2007 | 09:53 AM
mgags7's Avatar
No
You would let the clutch out while you're in-between gears to get the shafts spinning at the right rpm, with the clutch out and it in neutral, get the rpm to where you would be in the next gear, then put the clutch back in and go into gear.
That is how you shift a non-synchronized transmission, and how you should shift if you have a grind, unless of course you like bending things and getting metal shavings everywhere.
Old Mar 28, 2007 | 10:08 AM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">No
That is how you shift a non-synchronized transmission, and how you should shift if you have a grind, unless of course you like bending things and getting metal shavings everywhere.</TD></TR></TABLE>
ok i understand, basically i have to rev match like you would in a dog box since my synchros dont want to work. i wish i would have known that before becuase now my tranny wines at 10% throttle
Old Mar 28, 2007 | 11:39 AM
mgags7's Avatar
whining means you have something so out of whack that it is riding a shaft
usually a whine means a bad bearing
if it whines according to speed its the diff bearings
if it is according to the rpm it is a main or countershaft bearing.
Old Mar 28, 2007 | 11:48 AM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">whining means you have something so out of whack that it is riding a shaft
if it is according to the rpm it is a main or countershaft bearing.</TD></TR></TABLE>
wow, thank you very much, you are very knowledgable
it whines when im slowing down and still in gear at like 10mph and below, sounds like im in reverse. and it kinda whines just cruising at 10% throttle, if i let off the throttle it stops whining.
i have a feeling this is going to be a very expensive mistake
Old Mar 28, 2007 | 06:51 PM
blinx9900's Avatar
yeah its the countershaft bearing
Old May 8, 2007 | 12:36 PM
blinx9900's Avatar
quick update, my rod bearings and main bearings are effed up too... any help on acl part numbers for new bearings would be appreaciated.
jumpin4abeat
Jun 30, 2011 06:55 AM
svt13089
Jun 18, 2008 06:17 PM
BrokenLimits
11
Dec 7, 2005 09:34 AM
omg_miiiike
10
Apr 17, 2005 12:35 PM
hobo79
Aug 8, 2001 09:11 AM
