Camshaft install..Now car wont start.
Old Mar 26, 2007 | 08:23 PM
camboMONK's Avatar
Default Camshaft install..Now car wont start.
Installed Crower 403 camshaft and Blox IM in my B18a1 crx.
Cam gear, cyc #1 UP, and crank pulley is at TDC. Valves are adjusted .006 for intake and .008 exhaust when car is cold. Then I installed the Blox IM. I deleted the FITV because there isn't a mounting spot on the Blox IM. I just looped the coolant line that use to go to the FITV.
Now my problem is when I start the car, it is really rough. Car wont idle unless I give it gas. Motor run like IGN timing is all the way retarded. I pulled the spark plug and it's completely black (dry).
Please help.
Old Mar 26, 2007 | 08:53 PM
black88si's Avatar
Default Re: Camshaft install..Now car wont start. (camboMONK)
I know it sounds goofy, but are your plug wires on correctly.
Old Mar 26, 2007 | 10:21 PM
camboMONK's Avatar
Default Re: Camshaft install..Now car wont start. (black88si)
My firing order is correct. BUMP for suggestions.
Old Mar 26, 2007 | 10:24 PM
paulzy's Avatar
recheck your timing again.
Old Mar 26, 2007 | 11:11 PM
camboMONK's Avatar
Default Re: (paulzy)
will re-check timing tomorrow and post result. Thanks for helping.
Old Mar 27, 2007 | 01:34 AM
Redline130's Avatar
Check you ignition timing and also make sure both cams are lined up and not a tooth off from the other. Also, check to make sure all of your vacuum lines are routed correctly. More than anything, it sounds like a timing issue.
Old Mar 27, 2007 | 01:41 AM
EF7's Avatar
EF7
Default Re: Camshaft install..Now car wont start. (Redline130)
I had a similar problem, the cause was that the timing belt jump a tooth as I was putting everything back together.
Make sure the cams dont move, honda has a special 5mm pin that holds the cams in place, but you can use something else like a small screwdriver
Old Mar 28, 2007 | 04:15 PM
camboMONK's Avatar
Default Re: Camshaft install..Now car wont start. (EF7)
Thanks guys. Damn timing was off by 1 1/2 tooth. Everytime I would tighten the tensioner, the crank would rotate moving the pointer off the oil pump. I had to redo it 3x.
Old Mar 28, 2007 | 04:56 PM
Donkey85's Avatar
Old Mar 28, 2007 | 05:02 PM
crxpwr1's Avatar
Default Re: Camshaft install..Now car wont start. (Donkey85)
is this a fixed because his dizzy could be off timing 180 degrees...just a suggestion
Old Mar 28, 2007 | 06:04 PM
Crx Jimmy's Avatar
Default Re: Camshaft install..Now car wont start. (crxpwr1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 &raquo;</TD></TR><TR><TD CLASS="quote">is this a fixed because his dizzy could be off timing 180 degrees...just a suggestion</TD></TR></TABLE>
No it cant be 180 out. the key is offset so it cant go in wrong.
boostedteg69
Jul 28, 2011 02:02 PM
efjones9
Aug 7, 2010 10:35 AM
DB1_559
Jul 3, 2006 04:00 PM
1bar_ek
Jun 9, 2005 06:12 AM
intekragsr
Mar 21, 2003 10:23 AM
