MSD 2 step
Im new to it, I have a 6AL control modual, 2 step with push button, 3k-7k RPM pills, and a blaster coil. What else do I need to install it?
and how does 2 step work, Im a noob when it comes to it. I just want to know how to activate it, and basicly how to work it.
Thanks
Thanks
we ran ours with a MSD relay, a Hurst push button shift **** and wired it to the clutch switch like this:
to activate it - push the clutch in, touch the button on the shift **** and it will hold the revs at the first step of the 2 step - when you release the clutch, it will release the 1st step and then the 2nd step rev limiter takes over - we also had line-loc on ours, but it works the same without it
