msd 2 step button question...
Old Jul 3, 2009 | 11:44 PM
All_Motor_2o9's Avatar
Default msd 2 step button question...
well i need to set up a button for my msd 2 step. i am using a msd digital 6 plus, blaster 2 and pro cap w/ ngk wires on my ls turbo dc2.
all you need is a 12v constant to the 2 step wire and it initiates the retard. i tried the clutch switch (yes mine works, not jumped) and it would not produce 12v to start the 2 step.
so i just need an idea for a 2 step button and where to put it! i am willing to buy something. paypal friendly!! i would hate to have to get a b&m shift **** and replace my greddy counterweight shift ****... but i might have to unless you guys shoot me some ideas as to what the big boys use...
im just looking to shave some time off the 1/4 and get these tires to hook up real nice off the line
i just dont know where to rig a button? anyone got some pics of good ideas? i have pretty much everything aftermarket in the interior so just let me know what your 2 cents are! thanks!
Old Jul 4, 2009 | 12:30 AM
Default Re: msd 2 step button question...
i will buy this if i have to :/
http://cgi.ebay.com/ebaymotors/B-M-4...lenotsupported
Old Jul 4, 2009 | 10:45 AM
bump.
Old Jul 4, 2009 | 05:06 PM
bump.. cmon i just want ur 2 cents!!!
Old Jul 4, 2009 | 07:11 PM
slaminsam's Avatar
Well i have an idea... you could jump the connector and then run a 12v source to the actual switch to engage the 2 step... Since your turbo Im assuming you have some sort of tuning couldnt you have them burn another chip and just add launch control?
Old Jul 5, 2009 | 02:18 AM
launch control and 2 step are 2 different things. you cannot build boost off the line without the ignition being cut. when you cut fuel that is doing something else...
i need something for a switch.. i dont quite understand what your stabbing at
Old Jul 5, 2009 | 07:00 AM
slaminsam's Avatar
oh okay. What I was getting at is jump the connector from the switch like it was bad and then run a new wire that is pulling 12 volts to one side of the switch and on the other to the 2 step that needs the 12v. It would be just like the normal clutch switch except it will be 12v and only activating the two step.
cashshoes
Oct 5, 2007 04:37 AM
SupraRXZ
Mar 28, 2007 07:24 PM
insomniac791
Nov 25, 2003 06:48 PM
Drew M
May 13, 2002 09:04 AM
