msd two step
Old Oct 14, 2002 | 08:57 AM
burner's Avatar
Default msd two step
how do u guys activate your two step? is there any other way to activate this......instead of a button...........thanks for the reply
Old Oct 14, 2002 | 06:07 PM
wheemer's Avatar
Default Re: msd two step (burner)
Use your clutch pedal. It's got a start switch on it already just tap into it. That way when you have your clutch pressed in it will hold at the disired RPM.
Old Oct 14, 2002 | 07:50 PM
jlicrx's Avatar
Default Re: msd two step (wheemer)
we also have the line-loc hooked to the same switch
Old Oct 14, 2002 | 08:43 PM
saso
Guest
Posts: n/a
Default Re: msd two step (jlicrx)
on my street car I have it hookrd up to my windshield washer lever.
Old Oct 14, 2002 | 08:47 PM
MikeMAN's Avatar
thats an awsome idea!!!
Old Oct 14, 2002 | 08:55 PM
burner's Avatar
Default Re: msd two step (MikeMAN)
thanks for the reply guys ........i found another way to do it........i put it on the parking brake and it works well
Old Oct 15, 2002 | 08:47 PM
turbologist's Avatar
Default Re: msd two step (saso)
Saso,
Can you give us some more details on how you wired it up to your windshield washer switch? That sounds like a really good idea. Do you have the seperate 2-step that MSD sells or are you using the one that comes with the ignition amps?
Old Oct 16, 2002 | 03:08 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: msd two step (drealboostedhybrid)
I did a similiar technique.. i wired the 2 step to the horn button. the right button activates the horn still, and the left horn button keeps the rpms steady.. its not that hard to do, if yer electronically inclined...if any questions, email me, and if u decide to try it, DO NOT hit yer horn, other then when launching.. i barely use the horn anyway, or the car for that matter ...
Old Oct 18, 2002 | 10:51 AM
J-SPEC12's Avatar
Default Re: msd two step (SIXTYdashONE)
That's what I've used for the past 2 years it works great on the horn!
Old Oct 18, 2002 | 07:11 PM
SIK IN DA HED's Avatar
New User
Default Re: msd two step (J-SPEC12)
share us some installation steps on how to clutch activate the 2step. i also like the horn and windshield wiper idea. i currently have mine hooked up to a button on my center consol.
Old Oct 19, 2002 | 08:03 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: msd two step (dlplayboy)
clutch start safety switch is a grounding style switch, use it.
Thinking about installing a 2 step today......bracket racing tomorrow.
Old Oct 19, 2002 | 07:06 PM
Chugger's Avatar
Default Re: msd two step (Mista Bone)
how much does the msd 2-step usually run pricewise?
how easy is it to adjust the rpm point??
Old Oct 19, 2002 | 09:03 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: msd two step (Chugger)
2 step is $56 from Jegs. It plugs into a 6AL or SCI with revlimiter. You plug the 2 step into where the old revlimiter chip was, transfer that chip to the 2 step. then add whatever rpm chip you want the launch rpms at.
Also..........
Instead of bying more chips, you could buy a RPM module selector for $46, I'd choose the 6000-8200 unit, 200 rpm steps.
OR.........
You can add the "Launch Control Module Selector" $136, which is basically a 3 step and is adjustable in 100 rpm increments for the launch rpms. It has a "third step" that you would activate with a push button switch to limit burnout rpms.
Time for some bracket racing. Tomorrow is $25 to enter 13.99+ quick class, only had 7 cars last time. Win first round/quarters and win $75, win semis and get $150, win it all in the final and get $300.
Old Oct 20, 2002 | 09:05 AM
TurboDANDEE's Avatar
The MSD digital 6 has a built in 2 step, thats what im using. Mine is also hooked up to my clutch pedal. The clutch pedal throws out a negative signal, so you'll have to add a relay on the wire from the ignition box.
Old Oct 20, 2002 | 09:37 AM
turbotypeR@SPEC's Avatar
25 Year Member
i used to have mine hooked up to the clutch and it worked great until i started having axle problems.i learned that if you pre-load the clutch(thanks to turboR),the axles will hold up.only problem was then the clutch switch no longer worked.now i have it and a line-lock on a button and it works great.
Old Oct 23, 2002 | 07:39 PM
sporkcrx's Avatar
Default Re: msd two step (turbotypeR)
what's pre-loading the clutch?
Old Oct 24, 2002 | 03:39 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: msd two step (spoon2)
from the posts, holding e brake/hand brake to keep car from rolling, then letting the clutch just barely catch/slip, taking out the slack in the driveline.
Old Oct 24, 2002 | 05:03 AM
25 Year Member
letting out the clutch to right before it engages.there is a small space between the floor and when the clutch actually engages.if you let it go from the floor it is a huge shock to the drive train.let it out to right before it engages and let the clutch follow your foot out and it will be much smoother.
Old Oct 24, 2002 | 09:34 AM
Chugger's Avatar
i learn something new everyday
thanks h-t
hopefully no broken drivetrain parts for me (hopefully)
Old Oct 24, 2002 | 07:14 PM
redcxhatch's Avatar
Im gonna practice that, probably get better 60' too.
418whpturboD
Mar 19, 2008 05:10 PM
418whpturboD
Feb 26, 2008 05:28 AM
SPOOLINmatt
Mar 7, 2005 09:43 PM
egturbo
Feb 21, 2004 05:23 PM
underpressure02
Dec 22, 2003 04:11 PM
