off subject about impact guns..
Old Mar 26, 2007 | 10:56 AM
dem0nk1d's Avatar
Default off subject about impact guns..
now i just bought my first setup for air tools. i have a crappy husky 1/2 impact gun rated at 225ft/lbs, hooked up to a 10 gal tank. my question is that it can get off almost any nut and bolt on my car. But i am having one hell of a time getting the damn crank bolt loose. The air tank has a max of 125psi, and will not go any higher. Should I be looking into a better impact gun? Lets say something that has a max of 775ft/lbs. Some body please school me on this subject....
Old Mar 26, 2007 | 12:14 PM
Crazydave's Avatar
Default Re: off subject about impact guns.. (dem0nk1d)
search search search.
Crank pulley bolt and axle- nuts like to have >140 PSI on the air compressor
Also make sure that you are a using a REAL impact socket, and not a chrome socket.
Also hit the bolt/nut with quick reperative (1 second) blasts on the air gun.
Look closely at the tank for a Max Pressure Rating.
Your tank might be rated for 150, but has a shut-off at 125.
Also look for a blow-off (pressure relief valve) and see what it's rating it.
You might be able to adjust your pressure shut-off switch to higher PSI than 125
Old Mar 26, 2007 | 12:23 PM
dem0nk1d's Avatar
so your sayin git's not the gun. just need more psi.
i suppose i will have to check out the switch that regulates pressure.
Old Mar 26, 2007 | 01:17 PM
Crazydave's Avatar
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">so your sayin git's not the gun. just need more psi.
It's actually both.
pumping up the tank is a free upgrade though
Powered By Garrett
Nov 4, 2010 10:00 AM
bandit080000
17
Jun 11, 2009 12:20 AM
dbailey
18
Nov 27, 2005 04:20 PM
91CRXSI
14
May 3, 2002 06:39 PM
