Taking my tranny out! Need help! Can anyone give me a General Step By step?
Hey guys can someone help please Im about to Blow my brains out!
A general step by Step would be great! Thanks guys!
first disconnect battery.
Break hub nut on wheels loose 32mm
lift car up on jack stands
drain tranny of fluid
remove drive shafts
remove bolts associated with tranny on to engine
remove mounts
I'm doing it in a couple of days clutch is gone in my sedan
remove drive shafts
remove mounts
Your a Saint! Now I keep hearing about this PIN that is a bitch to get out...?? Where is that located? Just so I know to put up a fight. I have a YS1 trans off a b17A1. Thanks again bro! Thumbs
the shift linkage... should be a long 12mm bolt and then a pin... which would be the round shift link at the tranny.... not the bolt... just use a 10mm bolt or a punch... you want the same size as the pin, not something that is smaller there fore making the pin expand in size...
Not trying to be a dick, but your about one stop shy of asking someone to come to your house and do the job for you.
Just buy a manual. Read it. Then once you have a better idea of what your doing, post for any additional help you need.
0ptimus prime
Jul 17, 2004 11:17 PM
hatchback_al
Feb 12, 2004 10:30 PM
mingchi69
Sep 8, 2003 10:58 PM
AshlandSi
Oct 15, 2001 06:55 PM
